J’essaye de lancer VLC et Midoria via SSH mais je n’y arrive pas :
VLC
pi@raspberrypi:~ $ vlc Desktop/testt.mp4
VLC media player 3.0.11 Vetinari (revision 3.0.11-0-gdc0c5ced72)
[01a7b8c8] vlcpulse audio output error: PulseAudio server connection failure: Connection refused
[01a942c8] main interface error: no suitable interface module
[019fcb58] main libvlc error: interface "globalhotkeys,none" initialization failed
[019fcb58] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[01a942c8] skins2 interface error: cannot initialize OSFactory
[01a942c8] [cli] lua interface: Listening on host "*console".
Command Line Interface initialized. Type `help' for help.
> [b0207cb0] mmal_codec decoder: VCSM init succeeded: CMA
[b0207cb0] main decoder error: buffer deadlock prevented
[b0237378] gles2 generic error: parent window not available
[b0230f80] mmal_xsplitter vout display error: Failed to open Xsplitter:opengles2 module
[b0237378] xcb generic error: window not available
[b0230f80] mmal_xsplitter vout display error: Failed to open Xsplitter:xcb_x11 module
[01a942c8] [cli] lua interface error: Error loading script /usr/lib/arm-linux-gnueabihf/vlc/lua/intf/cli.luac: lua/intf/modules/host.lua:289: Interrupted.
Midori
pi@raspberrypi:~ $ midori www.google.fr
Unable to init server: Could not connect: Connection refused
(midori:972): Gtk-WARNING **: 17:41:19.701: cannot open display:
Pourriez vous m’aiguiller ?
Merci d’avance.
