Bonjour, j’espère que vous avez passé un bon weekend.
Voilà j’ai fini de faire les tests; voici les résultats.
Premier message
Voici le contenue des fichiers suivants :
/etc/hosts.allow :
sendmail: all
# /etc/hosts.allow: list of hosts that are allowed to access the system.
# See the manual pages hosts_access(5) and hosts_options(5).
# Example: ALL: LOCAL @some_netgroup
# ALL: .foobar.edu EXCEPT terminalserver.foobar.edu
# If you're going to protect the portmapper use the name "rpcbind" for the
# daemon name. See rpcbind(8) and rpc.mountd(8) for further information.
/etc/hosts.deny :
# /etc/hosts.deny: list of hosts that are _not_ allowed to access the system.
# Example: ALL: some.host.name, .some.domain
# ALL EXCEPT in.fingerd: other.host.name, .other.domain
# The PARANOID wildcard matches any host whose name does not match its
# address.
# You may wish to enable this to ensure any programs that don't
# validate looked up hostnames still leave understandable logs. In past
# versions of Debian this has been the default.
# ALL: PARANOID
Les fichiers /root/.ssh/config et /home/pi/.ssh/config n’éxistent pas.
Deuxième message
Piste 1 :
Temps de session active : 28min 43s
Retour de journalctl --since "-1 hour" :
-- Logs begin at Sat 2020-05-02 00:00:11 CEST, end at Sat 2020-05-02 21:00:47 CEST. --
mai 02 20:05:01 CRON[18461]: pam_unix(cron:session): session opened for user www-data by (uid=0)
mai 02 20:05:01 CRON[18465]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
mai 02 20:05:15 CRON[18461]: pam_unix(cron:session): session closed for user www-data
mai 02 20:09:01 CRON[18474]: pam_unix(cron:session): session opened for user root by (uid=0)
mai 02 20:09:01 CRON[18478]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
mai 02 20:09:01 CRON[18474]: pam_unix(cron:session): session closed for user root
mai 02 20:09:04 systemd[1]: Starting Clean php session files...
mai 02 20:09:04 systemd[1]: phpsessionclean.service: Succeeded.
mai 02 20:09:04 systemd[1]: Started Clean php session files.
mai 02 20:10:01 CRON[18553]: pam_unix(cron:session): session opened for user www-data by (uid=0)
mai 02 20:10:01 CRON[18557]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
mai 02 20:10:08 CRON[18553]: pam_unix(cron:session): session closed for user www-data
mai 02 20:12:59 systemd[1]: Reloading.
mai 02 20:13:01 systemd[1]: Starting Daily apt download activities...
mai 02 20:13:02 systemd[1]: Reloading.
mai 02 20:13:03 systemd[1]: apt-daily.service: Succeeded.
mai 02 20:13:03 systemd[1]: Started Daily apt download activities.
mai 02 20:13:04 systemd[1]: Reloading.
mai 02 20:13:06 systemd[1]: Reloading.
mai 02 20:13:11 systemd[1]: Reloading.
mai 02 20:13:12 systemd[1]: Reloading.
mai 02 20:13:13 systemd[1]: Reloading.
mai 02 20:13:14 systemd[1]: Reloading.
mai 02 20:13:15 systemd[1]: Reloading.
mai 02 20:13:17 systemd[1]: Reloading.
mai 02 20:13:18 systemd[1]: Reloading.
mai 02 20:13:21 userdel[19022]: delete user 'sshd'
mai 02 20:13:22 systemd[1]: Reloading.
mai 02 20:13:43 useradd[19229]: new user: name=sshd, UID=107, GID=65534, home=/run/sshd, shell=/usr/sbin/nologin
mai 02 20:13:43 usermod[19236]: change user 'sshd' password
mai 02 20:13:43 chage[19242]: changed password expiry for sshd
mai 02 20:13:44 systemd[1]: Reloading.
mai 02 20:13:45 systemd[1]: Reloading.
mai 02 20:13:46 systemd[1]: Reloading.
mai 02 20:13:47 systemd[1]: Reloading.
mai 02 20:13:48 systemd[1]: Starting OpenBSD Secure Shell server...
mai 02 20:13:48 sshd[19365]: Server listening on 0.0.0.0 port 22.
mai 02 20:13:48 sshd[19365]: Server listening on :: port 22.
mai 02 20:13:48 systemd[1]: Started OpenBSD Secure Shell server.
mai 02 20:13:48 systemd[1]: Reloading.
mai 02 20:13:59 sshd[19404]: Connection closed by 192.168.1.78 port 53580 [preauth]
mai 02 20:14:48 sshd[19407]: Accepted password for pi from 192.168.1.78 port 53590 ssh2
mai 02 20:14:48 sshd[19407]: pam_unix(sshd:session): session opened for user pi by (uid=0)
mai 02 20:14:48 systemd-logind[374]: New session c3 of user pi.
mai 02 20:14:48 systemd[1]: Started Session c3 of user pi.
mai 02 20:15:02 CRON[19430]: pam_unix(cron:session): session opened for user www-data by (uid=0)
mai 02 20:15:02 CRON[19434]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
mai 02 20:15:21 CRON[19430]: pam_unix(cron:session): session closed for user www-data
mai 02 20:17:01 CRON[19514]: pam_unix(cron:session): session opened for user root by (uid=0)
mai 02 20:17:02 CRON[19518]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
mai 02 20:17:02 CRON[19514]: pam_unix(cron:session): session closed for user root
mai 02 20:20:01 CRON[19589]: pam_unix(cron:session): session opened for user www-data by (uid=0)
mai 02 20:20:01 CRON[19593]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
mai 02 20:20:10 CRON[19589]: pam_unix(cron:session): session closed for user www-data
mai 02 20:25:01 CRON[19609]: pam_unix(cron:session): session opened for user www-data by (uid=0)
mai 02 20:25:01 CRON[19613]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
mai 02 20:25:13 CRON[19609]: pam_unix(cron:session): session closed for user www-data
mai 02 20:30:01 CRON[19634]: pam_unix(cron:session): session opened for user www-data by (uid=0)
mai 02 20:30:01 CRON[19638]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
mai 02 20:30:04 CRON[19634]: pam_unix(cron:session): session closed for user www-data
mai 02 20:30:43 rngd[363]: stats: bits received from HRNG source: 360064
mai 02 20:30:43 rngd[363]: stats: bits sent to kernel pool: 304608
mai 02 20:30:43 rngd[363]: stats: entropy added to kernel pool: 304608
mai 02 20:30:43 rngd[363]: stats: FIPS 140-2 successes: 18
mai 02 20:30:43 rngd[363]: stats: FIPS 140-2 failures: 0
mai 02 20:30:43 rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
mai 02 20:30:43 rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
mai 02 20:30:43 rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
mai 02 20:30:43 rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
mai 02 20:30:43 rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
mai 02 20:30:43 rngd[363]: stats: HRNG source speed: (min=552.996; avg=819.392; max=1000.064)Kibits/s
mai 02 20:30:43 rngd[363]: stats: FIPS tests speed: (min=4.187; avg=7.616; max=16.260)Mibits/s
mai 02 20:30:43 rngd[363]: stats: Lowest ready-buffers level: 2
mai 02 20:30:43 rngd[363]: stats: Entropy starvations: 0
mai 02 20:30:43 rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
mai 02 20:30:45 kernel: EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
mai 02 20:30:45 systemd[1]: ssh.service: Main process exited, code=killed, status=9/KILL
mai 02 20:30:45 systemd[1]: ssh.service: Failed with result 'signal'.
mai 02 20:30:45 systemd[1]: session-c3.scope: Succeeded.
mai 02 20:30:45 systemd-logind[374]: Session c3 logged out. Waiting for processes to exit.
mai 02 20:30:45 systemd-logind[374]: Removed session c3.
mai 02 20:30:45 systemd[1]: ssh.service: Service RestartSec=100ms expired, scheduling restart.
mai 02 20:30:45 systemd[1]: ssh.service: Scheduled restart job, restart counter is at 1.
mai 02 20:30:45 systemd[1]: Stopped OpenBSD Secure Shell server.
mai 02 20:30:45 sshd[19701]: /etc/ssh/sshd_config line 84: Unsupported option UsePAM
mai 02 20:30:45 systemd[1]: Starting OpenBSD Secure Shell server...
mai 02 20:30:45 sshd[19701]: Could not load host key: /etc/ssh/ssh_host_rsa_key
mai 02 20:30:45 sshd[19701]: Could not load host key: /etc/ssh/ssh_host_dsa_key
mai 02 20:30:45 sshd[19701]: Could not load host key: /etc/ssh/ssh_host_ecdsa_key
mai 02 20:30:45 sshd[19701]: Disabling protocol version 2. Could not load host key
mai 02 20:30:45 sshd[19701]: sshd: no hostkeys available -- exiting.
mai 02 20:30:45 systemd[1]: ssh.service: Control process exited, code=exited, status=1/FAILURE
mai 02 20:30:45 systemd[1]: ssh.service: Failed with result 'exit-code'.
mai 02 20:30:45 systemd[1]: Failed to start OpenBSD Secure Shell server.
mai 02 20:30:45 systemd[1]: ssh.service: Scheduled restart job, restart counter is at 2.
mai 02 20:30:45 sshd[19734]: /etc/ssh/sshd_config line 84: Unsupported option UsePAM
mai 02 20:30:45 sshd[19734]: Could not load host key: /etc/ssh/ssh_host_rsa_key
mai 02 20:30:45 sshd[19734]: Could not load host key: /etc/ssh/ssh_host_dsa_key
mai 02 20:30:45 sshd[19734]: Could not load host key: /etc/ssh/ssh_host_ecdsa_key
mai 02 20:30:45 sshd[19734]: Disabling protocol version 2. Could not load host key
mai 02 20:30:45 sshd[19734]: sshd: no hostkeys available -- exiting.
mai 02 20:30:45 systemd[1]: ssh.service: Scheduled restart job, restart counter is at 3.
mai 02 20:30:45 sshd[19746]: /etc/ssh/sshd_config line 84: Unsupported option UsePAM
mai 02 20:30:45 sshd[19746]: Could not load host key: /etc/ssh/ssh_host_rsa_key
mai 02 20:30:45 sshd[19746]: Could not load host key: /etc/ssh/ssh_host_dsa_key
mai 02 20:30:45 sshd[19746]: Could not load host key: /etc/ssh/ssh_host_ecdsa_key
mai 02 20:30:45 sshd[19746]: Disabling protocol version 2. Could not load host key
mai 02 20:30:45 sshd[19746]: sshd: no hostkeys available -- exiting.
mai 02 20:30:46 systemd[1]: ssh.service: Service RestartSec=100ms expired, scheduling restart.
mai 02 20:30:46 systemd[1]: ssh.service: Scheduled restart job, restart counter is at 4.
mai 02 20:30:46 systemd[1]: Stopped OpenBSD Secure Shell server.
mai 02 20:30:46 systemd[1]: Starting OpenBSD Secure Shell server...
mai 02 20:30:46 sshd[19762]: /etc/ssh/sshd_config line 84: Unsupported option UsePAM
mai 02 20:30:46 sshd[19762]: Could not load host key: /etc/ssh/ssh_host_rsa_key
mai 02 20:30:46 sshd[19762]: Could not load host key: /etc/ssh/ssh_host_dsa_key
mai 02 20:30:46 sshd[19762]: Could not load host key: /etc/ssh/ssh_host_ecdsa_key
mai 02 20:30:46 sshd[19762]: Disabling protocol version 2. Could not load host key
mai 02 20:30:46 sshd[19762]: sshd: no hostkeys available -- exiting.
mai 02 20:30:46 systemd[1]: ssh.service: Control process exited, code=exited, status=1/FAILURE
mai 02 20:30:46 systemd[1]: ssh.service: Failed with result 'exit-code'.
mai 02 20:30:46 systemd[1]: Failed to start OpenBSD Secure Shell server.
mai 02 20:30:46 systemd[1]: ssh.service: Scheduled restart job, restart counter is at 5.
mai 02 20:30:46 sshd[19775]: /etc/ssh/sshd_config line 84: Unsupported option UsePAM
mai 02 20:30:46 sshd[19775]: Could not load host key: /etc/ssh/ssh_host_rsa_key
mai 02 20:30:46 sshd[19775]: Could not load host key: /etc/ssh/ssh_host_dsa_key
mai 02 20:30:46 sshd[19775]: Could not load host key: /etc/ssh/ssh_host_ecdsa_key
mai 02 20:30:46 sshd[19775]: Disabling protocol version 2. Could not load host key
mai 02 20:30:46 sshd[19775]: sshd: no hostkeys available -- exiting.
mai 02 20:30:46 systemd[1]: ssh.service: Scheduled restart job, restart counter is at 6.
mai 02 20:30:46 systemd[1]: ssh.service: Start request repeated too quickly.
mai 02 20:31:00 systemd[1]: Reloading.
mai 02 20:31:01 systemd[1]: Reloading.
mai 02 20:31:02 systemd[1]: Reloading.
mai 02 20:31:03 systemd[1]: Reloading.
mai 02 20:31:05 systemd[1]: Reloading.
mai 02 20:31:06 systemd[1]: Reloading.
mai 02 20:31:07 systemd[1]: Reloading.
mai 02 20:31:09 systemd[1]: Reloading.
mai 02 20:31:10 systemd[1]: Reloading.
mai 02 20:31:11 systemd[1]: Reloading.
mai 02 20:31:12 systemd[1]: Reloading.
mai 02 20:31:15 userdel[20411]: delete user 'sshd'
mai 02 20:31:16 systemd[1]: Reloading.
mai 02 20:31:31 useradd[20618]: new user: name=sshd, UID=107, GID=65534, home=/run/sshd, shell=/usr/sbin/nologin
mai 02 20:31:31 usermod[20625]: change user 'sshd' password
mai 02 20:31:31 chage[20631]: changed password expiry for sshd
mai 02 20:31:32 systemd[1]: Reloading.
mai 02 20:31:33 systemd[1]: Reloading.
mai 02 20:31:34 systemd[1]: Reloading.
mai 02 20:31:35 systemd[1]: Reloading.
mai 02 20:31:36 systemd[1]: Starting OpenBSD Secure Shell server...
mai 02 20:31:36 sshd[20754]: Server listening on 0.0.0.0 port 22.
mai 02 20:31:36 sshd[20754]: Server listening on :: port 22.
mai 02 20:31:36 systemd[1]: Started OpenBSD Secure Shell server.
mai 02 20:31:36 systemd[1]: Reloading.
mai 02 20:31:55 sshd[20796]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=192.168.1.78 user=pi
mai 02 20:31:57 sshd[20796]: Failed password for pi from 192.168.1.78 port 53878 ssh2
mai 02 20:32:21 sshd[20796]: Failed password for pi from 192.168.1.78 port 53878 ssh2
mai 02 20:32:23 sshd[20796]: Accepted password for pi from 192.168.1.78 port 53878 ssh2
mai 02 20:32:23 sshd[20796]: pam_unix(sshd:session): session opened for user pi by (uid=0)
mai 02 20:32:23 systemd-logind[374]: New session c4 of user pi.
mai 02 20:32:23 systemd[1]: Started Session c4 of user pi.
mai 02 20:35:01 CRON[20823]: pam_unix(cron:session): session opened for user www-data by (uid=0)
mai 02 20:35:01 CRON[20827]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
mai 02 20:35:09 CRON[20823]: pam_unix(cron:session): session closed for user www-data
mai 02 20:39:01 CRON[20840]: pam_unix(cron:session): session opened for user root by (uid=0)
mai 02 20:39:01 CRON[20844]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
mai 02 20:39:01 CRON[20840]: pam_unix(cron:session): session closed for user root
mai 02 20:39:04 systemd[1]: Starting Clean php session files...
mai 02 20:39:05 systemd[1]: phpsessionclean.service: Succeeded.
mai 02 20:39:05 systemd[1]: Started Clean php session files.
mai 02 20:40:01 CRON[20917]: pam_unix(cron:session): session opened for user www-data by (uid=0)
mai 02 20:40:01 CRON[20921]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
mai 02 20:40:04 CRON[20917]: pam_unix(cron:session): session closed for user www-data
mai 02 20:45:01 CRON[20931]: pam_unix(cron:session): session opened for user www-data by (uid=0)
mai 02 20:45:01 CRON[20935]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
mai 02 20:45:05 CRON[20931]: pam_unix(cron:session): session closed for user www-data
mai 02 20:50:01 CRON[20946]: pam_unix(cron:session): session opened for user www-data by (uid=0)
mai 02 20:50:01 CRON[20950]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
mai 02 20:50:08 CRON[20946]: pam_unix(cron:session): session closed for user www-data
mai 02 20:55:01 CRON[20980]: pam_unix(cron:session): session opened for user www-data by (uid=0)
mai 02 20:55:01 CRON[20986]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
mai 02 20:55:07 CRON[20980]: pam_unix(cron:session): session closed for user www-data
mai 02 21:00:01 CRON[20997]: pam_unix(cron:session): session opened for user www-data by (uid=0)
mai 02 21:00:01 CRON[21001]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
mai 02 21:00:04 CRON[20997]: pam_unix(cron:session): session closed for user www-data
mai 02 21:00:45 kernel: EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
mai 02 21:00:45 systemd[1]: ssh.service: Main process exited, code=killed, status=9/KILL
mai 02 21:00:45 systemd[1]: ssh.service: Failed with result 'signal'.
mai 02 21:00:45 systemd-logind[374]: Session c4 logged out. Waiting for processes to exit.
mai 02 21:00:45 systemd[1]: session-c4.scope: Succeeded.
mai 02 21:00:45 systemd-logind[374]: Removed session c4.
mai 02 21:00:46 systemd[1]: ssh.service: Service RestartSec=100ms expired, scheduling restart.
mai 02 21:00:46 systemd[1]: ssh.service: Scheduled restart job, restart counter is at 1.
mai 02 21:00:46 systemd[1]: Stopped OpenBSD Secure Shell server.
mai 02 21:00:46 systemd[1]: Starting OpenBSD Secure Shell server...
mai 02 21:00:46 sshd[21093]: /etc/ssh/sshd_config line 84: Unsupported option UsePAM
mai 02 21:00:46 sshd[21093]: Could not load host key: /etc/ssh/ssh_host_rsa_key
mai 02 21:00:46 sshd[21093]: Could not load host key: /etc/ssh/ssh_host_dsa_key
mai 02 21:00:46 sshd[21093]: Could not load host key: /etc/ssh/ssh_host_ecdsa_key
mai 02 21:00:46 sshd[21093]: Disabling protocol version 2. Could not load host key
mai 02 21:00:46 sshd[21093]: sshd: no hostkeys available -- exiting.
mai 02 21:00:46 systemd[1]: ssh.service: Control process exited, code=exited, status=1/FAILURE
mai 02 21:00:46 systemd[1]: ssh.service: Failed with result 'exit-code'.
mai 02 21:00:46 systemd[1]: Failed to start OpenBSD Secure Shell server.
mai 02 21:00:46 systemd[1]: ssh.service: Scheduled restart job, restart counter is at 2.
mai 02 21:00:46 sshd[21102]: /etc/ssh/sshd_config line 84: Unsupported option UsePAM
mai 02 21:00:46 sshd[21102]: Could not load host key: /etc/ssh/ssh_host_rsa_key
mai 02 21:00:46 sshd[21102]: Could not load host key: /etc/ssh/ssh_host_dsa_key
mai 02 21:00:46 sshd[21102]: Could not load host key: /etc/ssh/ssh_host_ecdsa_key
mai 02 21:00:46 sshd[21102]: Disabling protocol version 2. Could not load host key
mai 02 21:00:46 sshd[21102]: sshd: no hostkeys available -- exiting.
mai 02 21:00:46 systemd[1]: ssh.service: Scheduled restart job, restart counter is at 3.
mai 02 21:00:46 sshd[21114]: /etc/ssh/sshd_config line 84: Unsupported option UsePAM
mai 02 21:00:46 sshd[21114]: Could not load host key: /etc/ssh/ssh_host_rsa_key
mai 02 21:00:46 sshd[21114]: Could not load host key: /etc/ssh/ssh_host_dsa_key
mai 02 21:00:46 sshd[21114]: Could not load host key: /etc/ssh/ssh_host_ecdsa_key
mai 02 21:00:46 sshd[21114]: Disabling protocol version 2. Could not load host key
mai 02 21:00:46 sshd[21114]: sshd: no hostkeys available -- exiting.
mai 02 21:00:46 systemd[1]: ssh.service: Scheduled restart job, restart counter is at 4.
mai 02 21:00:46 sshd[21123]: /etc/ssh/sshd_config line 84: Unsupported option UsePAM
mai 02 21:00:46 sshd[21123]: Could not load host key: /etc/ssh/ssh_host_rsa_key
mai 02 21:00:46 sshd[21123]: Could not load host key: /etc/ssh/ssh_host_dsa_key
mai 02 21:00:46 sshd[21123]: Could not load host key: /etc/ssh/ssh_host_ecdsa_key
mai 02 21:00:46 sshd[21123]: Disabling protocol version 2. Could not load host key
mai 02 21:00:46 sshd[21123]: sshd: no hostkeys available -- exiting.
mai 02 21:00:47 systemd[1]: ssh.service: Service RestartSec=100ms expired, scheduling restart.
mai 02 21:00:47 systemd[1]: ssh.service: Scheduled restart job, restart counter is at 5.
mai 02 21:00:47 systemd[1]: Stopped OpenBSD Secure Shell server.
mai 02 21:00:47 systemd[1]: Starting OpenBSD Secure Shell server...
mai 02 21:00:47 sshd[21144]: /etc/ssh/sshd_config line 84: Unsupported option UsePAM
mai 02 21:00:47 sshd[21144]: Could not load host key: /etc/ssh/ssh_host_rsa_key
mai 02 21:00:47 sshd[21144]: Could not load host key: /etc/ssh/ssh_host_dsa_key
mai 02 21:00:47 sshd[21144]: Could not load host key: /etc/ssh/ssh_host_ecdsa_key
mai 02 21:00:47 sshd[21144]: Disabling protocol version 2. Could not load host key
mai 02 21:00:47 sshd[21144]: sshd: no hostkeys available -- exiting.
mai 02 21:00:47 systemd[1]: ssh.service: Control process exited, code=exited, status=1/FAILURE
mai 02 21:00:47 systemd[1]: ssh.service: Failed with result 'exit-code'.
mai 02 21:00:47 systemd[1]: Failed to start OpenBSD Secure Shell server.
mai 02 21:00:47 systemd[1]: ssh.service: Scheduled restart job, restart counter is at 6.
mai 02 21:00:47 systemd[1]: ssh.service: Start request repeated too quickly.
Piste 2
La session a été killer après : 19min.
Piste 3
La session a été killer après 21min et 19s.
Piste 4
Temps de session active : 10min 2s
Piste 5
Temps de session active : 20min
Petite chose à rajouté le serveur ssh à démarrer apres la réparation du système de fichier mais (chose inhabituelle) mais ce coupe toujours et impossible de le redémarrer. (sauf avec apt purge…)
Merci encore pour le temps que vous y consacrez
Bonne journée
