Bonour, j’ai instaler sickchill sur mon raspberry mais les télechargement ne se lance pas, pouriez vous m’aidez, voici mes logs :
2018-12-09 10:20:28 INFO SEARCHQUEUE-DAILY-SEARCH :: No needed episodes found
2018-12-09 10:20:27 INFO SEARCHQUEUE-DAILY-SEARCH :: Beginning daily search for new episodes
2018-12-09 10:20:26 INFO DAILYSEARCHER :: No new released episodes found …
2018-12-09 10:20:26 INFO DAILYSEARCHER :: Searching for new released episodes …
2018-12-09 10:15:53 WARNING ThreadPoolExecutor-0_0 :: Failed to detect KODI version for ‹ 192.168.1.20:8080 ›, check configuration and try again.
2018-12-09 10:15:53 WARNING ThreadPoolExecutor-0_0 :: Error while trying to retrieve KODI API version for 192.168.1.20:8080: u’error [Errno 111] Connection refused’
2018-12-09 10:15:39 WARNING ThreadPoolExecutor-0_0 :: Failed to detect KODI version for ‹ 192.168.1.20:8080 ›, check configuration and try again.
2018-12-09 10:15:39 WARNING ThreadPoolExecutor-0_0 :: Error while trying to retrieve KODI API version for 192.168.1.20:8080: u’error [Errno 111] Connection refused’
2018-12-09 10:11:51 INFO SEARCHQUEUE-DAILY-SEARCH :: No needed episodes found
2018-12-09 10:11:51 INFO SEARCHQUEUE-DAILY-SEARCH :: [Torrent9] :: Request failed: HTTPSConnectionPool(host=‹ www.torrent9.chtorrent ›, port=443): Max retries exceeded with url: /4244/neuilly-sa-mere-sa-mere (Caused by NewConnectionError(‹ : Failed to establish a new connection: [Errno -2] Name or service not known ›,)) ()
2018-12-09 10:11:51 INFO SEARCHQUEUE-DAILY-SEARCH :: [Torrent9] :: Request failed: HTTPSConnectionPool(host=‹ www.torrent9.chtorrent ›, port=443): Max retries exceeded with url: /4245/neuilly-sa-mere-sa-mere (Caused by NewConnectionError(‹ : Failed to establish a new connection: [Errno -2] Name or service not known ›,)) ()
2018-12-09 10:11:50 INFO SEARCHQUEUE-DAILY-SEARCH :: [Torrent9] :: Request failed: HTTPSConnectionPool(host=‹ www.torrent9.chtorrent ›, port=443): Max retries exceeded with url: /4246/neuilly-sa-mere-sa-mere (Caused by NewConnectionError(‹ : Failed to establish a new connection: [Errno -2] Name or service not known ›,)) ()
2018-12-09 10:11:50 INFO SEARCHQUEUE-DAILY-SEARCH :: [Torrent9] :: Request failed: HTTPSConnectionPool(host=‹ www.torrent9.chtorrent ›, port=443): Max retries exceeded with url: /4259/zoe-et-raven-noel-ensemble (Caused by NewConnectionError(‹ : Failed to establish a new connection: [Errno -2] Name or service not known ›,)) ()
2018-12-09 10:11:50 INFO SEARCHQUEUE-DAILY-SEARCH :: [Torrent9] :: Request failed: HTTPSConnectionPool(host=‹ www.torrent9.chtorrent ›, port=443): Max retries exceeded with url: /4260/zoe-et-raven-noel-ensemble (Caused by NewConnectionError(‹ : Failed to establish a new connection: [Errno -2] Name or service not known ›,)) ()
2018-12-09 10:11:50 INFO SEARCHQUEUE-DAILY-SEARCH :: [Torrent9] :: Request failed: HTTPSConnectionPool(host=‹ www.torrent9.chtorrent ›, port=443): Max retries exceeded with url: /4264/the-guilty (Caused by NewConnectionError(‹ : Failed to establish a new connection: [Errno -2] Name or service not known ›,)) ()
2018-12-09 10:11:50 INFO SEARCHQUEUE-DAILY-SEARCH :: [Torrent9] :: Request failed: HTTPSConnectionPool(host=‹ www.torrent9.chtorrent ›, port=443): Max retries exceeded with url: /4265/the-guilty (Caused by NewConnectionError(‹ : Failed to establish a new connection: [Errno -2] Name or service not known ›,)) ()
2018-12-09 10:11:50 INFO SEARCHQUEUE-DAILY-SEARCH :: [Torrent9] :: Request failed: HTTPSConnectionPool(host=‹ www.torrent9.chtorrent ›, port=443): Max retries exceeded with url: /4266/the-guilty (Caused by NewConnectionError(‹ : Failed to establish a new connection: [Errno -2] Name or service not known ›,)) ()
2018-12-09 10:11:50 INFO SEARCHQUEUE-DAILY-SEARCH :: [Torrent9] :: Request failed: HTTPSConnectionPool(host=‹ www.torrent9.chtorrent ›, port=443): Max retries exceeded with url: /4267/the-predator (Caused by NewConnectionError(‹ : Failed to establish a new connection: [Errno -2] Name or service not known ›,)) ()
2018-12-09 10:11:50 INFO SEARCHQUEUE-DAILY-SEARCH :: [Torrent9] :: Request failed: HTTPSConnectionPool(host=‹ www.torrent9.chtorrent ›, port=443): Max retries exceeded with url: /4268/the-predator (Caused by NewConnectionError(‹ : Failed to establish a new connection: [Errno -2] Name or service not known ›,)) ()
2018-12-09 10:11:50 INFO SEARCHQUEUE-DAILY-SEARCH :: [Torrent9] :: Request failed: HTTPSConnectionPool(host=‹ www.torrent9.chtorrent ›, port=443): Max retries exceeded with url: /4269/the-predator (Caused by NewConnectionError(‹ : Failed to establish a new connection: [Errno -2] Name or service not known ›,)) ()
2018-12-09 10:11:50 INFO SEARCHQUEUE-DAILY-SEARCH :: [Torrent9] :: Request failed: HTTPSConnectionPool(host=‹ www.torrent9.chtorrent ›, port=443): Max retries exceeded with url: /4270/the-predator (Caused by NewConnectionError(‹ : Failed to establish a new connection: [Errno -2] Name or service not known ›,)) ()
2018-12-09 10:11:50 INFO SEARCHQUEUE-DAILY-SEARCH :: [Torrent9] :: Request failed: HTTPSConnectionPool(host=‹ www.torrent9.chtorrent ›, port=443): Max retries exceeded with url: /4271/the-predator (Caused by NewConnectionError(‹ : Failed to establish a new connection: [Errno -2] Name or service not known ›,)) ()
2018-12-09 10:11:50 INFO SEARCHQUEUE-DAILY-SEARCH :: [Torrent9] :: Request failed: HTTPSConnectionPool(host=‹ www.torrent9.chtorrent ›, port=443): Max retries exceeded with url: /4272/the-predator (Caused by NewConnectionError(‹ : Failed to establish a new connection: [Errno -2] Name or service not known ›,)) ()
2018-12-09 10:11:50 INFO SEARCHQUEUE-DAILY-SEARCH :: [Torrent9] :: Request failed: HTTPSConnectionPool(host=‹ www.torrent9.chtorrent ›, port=443): Max retries exceeded with url: /4273/bloodrunners (Caused by NewConnectionError(‹ : Failed to establish a new connection: [Errno -2] Name or service not known ›,)) ()
2018-12-09 10:11:27 INFO SEARCHQUEUE-DAILY-SEARCH :: [LimeTorrents] :: Request failed: HTTPSConnectionPool(host=‹ www.limetorrents.cc ›, port=443): Max retries exceeded with url: /rss/tv/ (Caused by NewConnectionError(‹ : Failed to establish a new connection: [Errno 111] Connection refused ›,)) ()
2018-12-09 10:10:48 INFO SEARCHQUEUE-DAILY-SEARCH :: [SkyTorrents] :: Request failed: 404 Client Error: Not Found for url: https://www.skytorrents.lol/rss?sort=created&query=&tag=hd&type=video&sort=created&query=&tag=hd&type=video&sort=created&query=&tag=hd&type=video ()
Failed to establish a new connection: [Errno 111] Connection refused’
Je ne connais pas du tout ton appli ou ce qu’elle fait mais vu les erreurs assez génériques, je pencherais pour un matériel qui n’est pas connecté au réseau ou que la résolution DNS n’est pas bonne.
L’aplicatIon c’est Sickrage en fait
