À partir d’un Pi OS Lite 64 bits, je désirerais cloner le système, mais je ne comprends où est l’erreur sauf si c’est la légère différence de stockage entre les 2 cartes
D’avance merci !
sudo rpi-clone sda -v
Booted disk: mmcblk0 31,9GB Destination disk: sda 31,3GB
Part Size FS Label Part Size FS Label
1 /boot 256 0M fat32 – 1 256 0M fat32 –
2 root 29 5G ext4 rootfs 2 28 9G – –
== Initialize: IMAGE partition table - FS types conflict ==
1 /boot (49,5M used) : MKFS SYNC to sda1
2 root (2,2G used) : RESIZE MKFS SYNC to sda2
Run setup script : no.
Verbose mode : yes.
** WARNING ** : All destination disk sda data will be overwritten!
Initialize and clone to the destination disk sda? (yes/no): yes
Optional destination ext type file system label (16 chars max): os pi lite 64
Initializing
Imaging past partition 1 start.
=> dd if=/dev/mmcblk0 of=/dev/sda bs=1M count=8 …
Resizing destination disk last partition …
Resize success.
Changing destination Disk ID …
=> mkfs -t vfat -F 32 /dev/sda1 …
=> mkfs -t ext4 -L os pi lite 64 /dev/sda2 …
Syncing file systems (can take a long time)
Syncing mounted partitions:
Mounting /dev/sda2 on /mnt/clone
mount: /mnt/clone: wrong fs type, bad option, bad superblock on /dev/sda2, missing codepage or helper program, or other error.
Mount failure of /dev/sda2 on /mnt/clone.
Aborting!
