[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.4.51-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1333 SMP Mon Aug 10 16:45:19 BST 2020
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x37400000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 242688
[ 0.000000] Normal zone: 2133 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 242688 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s49856 r8192 d23872 u81920
[ 0.000000] pcpu-alloc: s49856 r8192 d23872 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240555
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=720 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=60760868-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 881512K/970752K available (8192K kernel code, 689K rwdata, 2552K rodata, 1024K init, 825K bss, 23704K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 28275 entries in 56 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x328/0x500 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000019] Switching to timer-based delay loop, resolution 52ns
[ 0.000284] Console: colour dummy device 80x30
[ 0.000312] printk: console [tty1] enabled
[ 0.000362] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=192000)
[ 0.000380] pid_max: default: 32768 minimum: 301
[ 0.000763] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.000783] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002136] Disabling memory control group subsystem
[ 0.002238] CPU: Testing write buffer coherency: ok
[ 0.002796] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.003727] Setting up static identity map for 0x100000 - 0x10003c
[ 0.003923] rcu: Hierarchical SRCU implementation.
[ 0.004601] smp: Bringing up secondary CPUs …
[ 0.005715] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.006975] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.008120] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.008272] smp: Brought up 1 node, 4 CPUs
[ 0.008287] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.008297] CPU: All CPU(s) started in HYP mode.
[ 0.008306] CPU: Virtualization extensions available.
[ 0.009284] devtmpfs: initialized
[ 0.025990] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.026256] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.026282] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.029331] pinctrl core: initialized pinctrl subsystem
[ 0.030569] NET: Registered protocol family 16
[ 0.034927] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.041331] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.041343] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.041573] Serial: AMBA PL011 UART driver
[ 0.043547] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.060099] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-08-06 16:24, variant start
[ 0.070118] raspberrypi-firmware soc:firmware: Firmware hash is af3edc2de473197cdfe1ff5a8ff2d34095d5b336
[ 0.121788] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.123977] SCSI subsystem initialized
[ 0.124231] usbcore: registered new interface driver usbfs
[ 0.124293] usbcore: registered new interface driver hub
[ 0.124419] usbcore: registered new device driver usb
[ 0.126502] clocksource: Switched to clocksource arch_sys_counter
[ 1.287689] VFS: Disk quotas dquot_6.6.0
[ 1.287804] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.288000] FS-Cache: Loaded
[ 1.288272] CacheFiles: Loaded
[ 1.299365] thermal_sys: Registered thermal governor ‹ step_wise ›
[ 1.299764] NET: Registered protocol family 2
[ 1.300799] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.300845] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.300960] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.301149] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.301312] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.301365] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.301657] NET: Registered protocol family 1
[ 1.302360] RPC: Registered named UNIX socket transport module.
[ 1.302370] RPC: Registered udp transport module.
[ 1.302380] RPC: Registered tcp transport module.
[ 1.302389] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.304214] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.307560] Initialise system trusted keyrings
[ 1.307817] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 1.319600] FS-Cache: Netfs ‹ nfs › registered for caching
[ 1.320397] NFS: Registering the id_resolver key type
[ 1.320446] Key type id_resolver registered
[ 1.320457] Key type id_legacy registered
[ 1.320477] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.321791] Key type asymmetric registered
[ 1.321804] Asymmetric key parser ‹ x509 › registered
[ 1.321854] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.321866] io scheduler mq-deadline registered
[ 1.321877] io scheduler kyber registered
[ 1.325319] bcm2708_fb soc:fb: FB found 1 display(s)
[ 1.345043] Console: switching to colour frame buffer device 160x45
[ 1.360678] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1280x720
[ 1.365813] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.366292] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.367055] vc-sm: Videocore shared memory driver
[ 1.367511] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 1.380458] brd: module loaded
[ 1.393075] loop: module loaded
[ 1.394447] Loading iSCSI transport class v2.0-870.
[ 1.395313] libphy: Fixed MDIO Bus: probed
[ 1.395428] usbcore: registered new interface driver lan78xx
[ 1.395491] usbcore: registered new interface driver smsc95xx
[ 1.395515] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.124349] Core Release: 2.80a
[ 2.124363] Setting default values for core params
[ 2.124398] Finished setting default values for core params
[ 2.324786] Using Buffer DMA mode
[ 2.324798] Periodic Transfer Interrupt Enhancement - disabled
[ 2.324807] Multiprocessor Interrupt Enhancement - disabled
[ 2.324819] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.324845] Dedicated Tx FIFOs mode
[ 2.325563] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b7514000 dma = 0xf7514000 len=9024
[ 2.325594] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 2.325606] dwc_otg: Microframe scheduler enabled
[ 2.325670] WARN::hcd_init_fiq:457: FIQ on core 1
[ 2.325680] WARN::hcd_init_fiq:458: FIQ ASM at 806d89f4 length 36
[ 2.325692] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
[ 2.325714] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.325753] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.325800] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
[ 2.325853] Init: Port Power? op_state=1
[ 2.325863] Init: Power Port (0)
[ 2.326236] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 2.326252] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.326266] usb usb1: Product: DWC OTG Controller
[ 2.326280] usb usb1: Manufacturer: Linux 5.4.51-v7+ dwc_otg_hcd
[ 2.326293] usb usb1: SerialNumber: 3f980000.usb
[ 2.327013] hub 1-0:1.0: USB hub found
[ 2.327075] hub 1-0:1.0: 1 port detected
[ 2.327855] dwc_otg: FIQ enabled
[ 2.327865] dwc_otg: NAK holdoff enabled
[ 2.327875] dwc_otg: FIQ split-transaction FSM enabled
[ 2.327890] Module dwc_common_port init
[ 2.328234] usbcore: registered new interface driver usb-storage
[ 2.328434] mousedev: PS/2 mouse device common for all mice
[ 2.329766] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 2.331191] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 600000 KHz
[ 2.334013] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 700000 KHz
[ 2.334619] sdhci: Secure Digital Host Controller Interface driver
[ 2.334628] sdhci: Copyright© Pierre Ossman
[ 2.335120] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 2.335660] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 2.335841] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.337544] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.337864] hidraw: raw HID events driver © Jiri Kosina
[ 2.338015] usbcore: registered new interface driver usbhid
[ 2.338023] usbhid: USB HID core driver
[ 2.338901] vchiq: vchiq_init_state: slot_zero = (ptrval)
[ 2.340515] [vc_sm_connected_init]: start
[ 2.349219] [vc_sm_connected_init]: end - returning 0
[ 2.350953] Initializing XFRM netlink socket
[ 2.350987] NET: Registered protocol family 17
[ 2.351113] Key type dns_resolver registered
[ 2.351809] Registering SWP/SWPB emulation handler
[ 2.352104] registered taskstats version 1
[ 2.352122] Loading compiled-in X.509 certificates
[ 2.352593] Key type ._fscrypt registered
[ 2.352603] Key type .fscrypt registered
[ 2.362043] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 2.362125] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 2.363857] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 2.365175] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 2.365187] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 2.390160] sdhost: log_buf @ (ptrval) (f7513000)
[ 2.427267] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.428889] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.430497] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.433377] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.440174] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 2.442414] of_cfs_init
[ 2.442536] of_cfs_init: OK
[ 2.463550] Waiting for root device PARTUUID=60760868-02…
[ 2.500887] random: fast init done
[ 2.539634] mmc1: new high speed SDIO card at address 0001
[ 2.546630] Indeed it is in host mode hprt0 = 00021501
[ 2.756531] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.756676] Indeed it is in host mode hprt0 = 00001101
[ 2.996814] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 2.996828] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.997388] hub 1-1:1.0: USB hub found
[ 2.997484] hub 1-1:1.0: 4 ports detected
[ 3.316528] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.446819] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 3.446833] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.447348] hub 1-1.1:1.0: USB hub found
[ 3.447447] hub 1-1.1:1.0: 3 ports detected
[ 3.546536] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[ 3.712981] usb 1-1.2: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
[ 3.712995] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.713006] usb 1-1.2: Product: ZiGate
[ 3.713019] usb 1-1.2: Manufacturer: Silicon Labs
[ 3.713030] usb 1-1.2: SerialNumber: 0001
[ 3.776533] usb 1-1.1.3: new high-speed USB device number 5 using dwc_otg
[ 3.907468] usb 1-1.1.3: New USB device found, idVendor=0781, idProduct=558b, bcdDevice= 1.00
[ 3.907483] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.907495] usb 1-1.1.3: Product: Extreme
[ 3.907506] usb 1-1.1.3: Manufacturer: SanDisk
[ 3.907518] usb 1-1.1.3: SerialNumber: 4C530000120522213401
[ 3.908179] usb-storage 1-1.1.3:1.0: USB Mass Storage device detected
[ 3.908810] scsi host0: usb-storage 1-1.1.3:1.0
[ 4.025553] usb 1-1.3: new high-speed USB device number 6 using dwc_otg
[ 4.147568] usb 1-1.3: New USB device found, idVendor=12d1, idProduct=1506, bcdDevice= 1.02
[ 4.147583] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.147595] usb 1-1.3: Product: HUAWEI_MOBILE
[ 4.147606] usb 1-1.3: Manufacturer: HUAWEI_MOBILE
[ 4.176824] usb-storage 1-1.3:1.3: USB Mass Storage device detected
[ 4.177295] scsi host1: usb-storage 1-1.3:1.3
[ 4.178014] usb-storage 1-1.3:1.4: USB Mass Storage device detected
[ 4.178486] scsi host2: usb-storage 1-1.3:1.4
[ 4.246538] usb 1-1.1.1: new high-speed USB device number 7 using dwc_otg
[ 4.376980] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[ 4.376994] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.641891] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
[ 4.642958] libphy: lan78xx-mdiobus: probed
[ 4.649912] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[ 4.957202] scsi 0:0:0:0: Direct-Access SanDisk Extreme 1.00 PQ: 0 ANSI: 6
[ 4.958108] sd 0:0:0:0: [sda] 122552320 512-byte logical blocks: (62.7 GB/58.4 GiB)
[ 4.959157] sd 0:0:0:0: [sda] Write Protect is off
[ 4.959172] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 4.959646] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 4.963984] sda: sda1 sda2
[ 4.966453] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 5.020646] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 5.020728] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
[ 5.023515] devtmpfs: mounted
[ 5.030290] Freeing unused kernel memory: 1024K
[ 5.036894] Run /sbin/init as init process
[ 5.200345] scsi 2:0:0:0: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
[ 5.200982] scsi 1:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
[ 5.201932] sd 2:0:0:0: Power-on or device reset occurred
[ 5.268432] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[ 5.563098] systemd[1]: System time before build time, advancing clock.
[ 5.684745] NET: Registered protocol family 10
[ 5.686204] Segment Routing with IPv6
[ 5.737773] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 5.738705] systemd[1]: Detected architecture arm.
[ 5.789582] systemd[1]: Set hostname to .
[ 6.555750] systemd[1]: /lib/systemd/system/fail2ban.service:12: PIDFile= references path below legacy directory /var/run/, updating /var/run/fail2ban/fail2ban.pid → /run/fail2ban/fail2ban.pid; please update the unit file accordingly.
[ 6.670588] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.684140] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.684772] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.685344] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.685971] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.688006] systemd[1]: Created slice User and Session Slice.
[ 6.688902] systemd[1]: Listening on Journal Socket.
[ 6.694903] systemd[1]: Starting Create list of required static device nodes for the current kernel…
[ 6.700185] systemd[1]: Mounting RPC Pipe File System…
[ 6.971617] i2c /dev entries driver
[ 7.019528] random: crng init done
[ 7.019545] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.607029] EXT4-fs (sda2): re-mounted. Opts: (null)
[ 7.701242] systemd-journald[115]: Received request to flush runtime journal from PID 1
[ 8.433408] mc: Linux media interface: v0.10
[ 8.441215] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.443562] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 8.443582] [vc_sm_connected_init]: start
[ 8.446073] [vc_sm_connected_init]: installed successfully
[ 8.500405] videodev: Linux video capture interface: v2.00
[ 8.569067] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.569071] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.571399] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.584007] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.610149] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.665756] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.671372] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.675534] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 8.681197] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 8.682823] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 8.682886] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 8.684120] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 8.685714] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 8.690566] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 8.691571] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 8.691614] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 8.691976] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 8.692000] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 8.692016] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 8.692032] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 8.692047] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 8.692242] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 8.697385] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 8.697436] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 9.092826] usbcore: registered new interface driver uas
[ 9.100327] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 9.104141] usbcore: registered new interface driver usbserial_generic
[ 9.104204] usbserial: USB Serial support registered for generic
[ 9.109813] usbcore: registered new interface driver cp210x
[ 9.109901] usbserial: USB Serial support registered for cp210x
[ 9.110083] cp210x 1-1.2:1.0: cp210x converter detected
[ 9.127943] usb 1-1.2: cp210x converter now attached to ttyUSB0
[ 9.202561] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 9.202857] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 9.203053] scsi 1:0:0:0: Attached scsi generic sg2 type 5
[ 9.263431] cfg80211: Loaded X.509 cert ‹ sforshee: 00b28ddf47aef9cea7 ›
[ 9.314610] usbcore: registered new interface driver option
[ 9.314695] usbserial: USB Serial support registered for GSM modem (1-port)
[ 9.315287] option 1-1.3:1.0: GSM modem (1-port) converter detected
[ 9.335106] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB1
[ 9.335861] option 1-1.3:1.1: GSM modem (1-port) converter detected
[ 9.336343] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB2
[ 9.399861] usbcore: registered new interface driver cdc_ncm
[ 9.417833] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 9.426813] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 9.427298] usbcore: registered new interface driver brcmfmac
[ 9.445562] usbcore: registered new interface driver cdc_wdm
[ 9.460395] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,3-model-b-plus.txt failed with error -2
[ 9.569836] huawei_cdc_ncm 1-1.3:1.2: MAC-Address: 00:1e:10:1f:00:00
[ 9.569862] huawei_cdc_ncm 1-1.3:1.2: setting rx_max = 16384
[ 9.575661] huawei_cdc_ncm 1-1.3:1.2: NDP will be placed at end of frame for this device.
[ 9.575966] huawei_cdc_ncm 1-1.3:1.2: cdc-wdm0: USB WDM device
[ 9.577387] huawei_cdc_ncm 1-1.3:1.2 wwan0: register ‹ huawei_cdc_ncm › at usb-3f980000.usb-1.3, Huawei CDC NCM device, 00:1e:10:1f:00:00
[ 9.577620] usbcore: registered new interface driver huawei_cdc_ncm
[ 9.598995] sr 1:0:0:0: Power-on or device reset occurred
[ 9.612037] sr 1:0:0:0: [sr0] scsi-1 drive
[ 9.612086] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 9.649104] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 9.711012] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 9.725464] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 2 2020 23:30:41 version 7.45.202 (r724630 CY) FWID 01-72f6ece2
[ 10.331469] sr 1:0:0:0: [sr0] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[ 10.331492] sr 1:0:0:0: [sr0] tag#0 Sense Key : 0x3 [current]
[ 10.331507] sr 1:0:0:0: [sr0] tag#0 ASC=0x11 ASCQ=0x0
[ 10.331525] sr 1:0:0:0: [sr0] tag#0 CDB: opcode=0x28 28 00 00 00 91 fc 00 00 02 00
[ 10.331543] blk_update_request: critical medium error, dev sr0, sector 149488 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 10.331606] attempt to access beyond end of device
[ 10.331619] sr0: rw=0, want=149496, limit=149488
[ 10.331633] Buffer I/O error on dev sr0, logical block 18686, async page read
[ 10.374883] sr 1:0:0:0: [sr0] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[ 10.374907] sr 1:0:0:0: [sr0] tag#0 Sense Key : 0x3 [current]
[ 10.374922] sr 1:0:0:0: [sr0] tag#0 ASC=0x11 ASCQ=0x0
[ 10.374941] sr 1:0:0:0: [sr0] tag#0 CDB: opcode=0x28 28 00 00 00 90 80 00 00 3c 00
[ 10.374960] blk_update_request: critical medium error, dev sr0, sector 147968 op 0x0:(READ) flags 0x80700 phys_seg 3 prio class 0
[ 10.385347] sr 1:0:0:0: [sr0] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[ 10.385371] sr 1:0:0:0: [sr0] tag#0 Sense Key : 0x3 [current]
[ 10.385385] sr 1:0:0:0: [sr0] tag#0 ASC=0x11 ASCQ=0x0
[ 10.385405] sr 1:0:0:0: [sr0] tag#0 CDB: opcode=0x28 28 00 00 00 90 80 00 00 02 00
[ 10.385424] blk_update_request: critical medium error, dev sr0, sector 147968 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 10.385440] Buffer I/O error on dev sr0, logical block 18496, async page read
[ 10.390631] sr 1:0:0:0: [sr0] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[ 10.390656] sr 1:0:0:0: [sr0] tag#0 Sense Key : 0x3 [current]
[ 10.390671] sr 1:0:0:0: [sr0] tag#0 ASC=0x11 ASCQ=0x0
[ 10.390689] sr 1:0:0:0: [sr0] tag#0 CDB: opcode=0x28 28 00 00 00 91 fa 00 00 02 00
[ 10.390708] blk_update_request: critical medium error, dev sr0, sector 149480 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 10.390797] attempt to access beyond end of device
[ 10.390809] sr0: rw=0, want=149488, limit=149480
[ 10.390824] Buffer I/O error on dev sr0, logical block 18685, async page read
[ 10.464400] sr 1:0:0:0: [sr0] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[ 10.464425] sr 1:0:0:0: [sr0] tag#0 Sense Key : 0x3 [current]
[ 10.464440] sr 1:0:0:0: [sr0] tag#0 ASC=0x11 ASCQ=0x0
[ 10.464458] sr 1:0:0:0: [sr0] tag#0 CDB: opcode=0x28 28 00 00 00 91 f6 00 00 02 00
[ 10.464477] blk_update_request: critical medium error, dev sr0, sector 149464 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 10.464565] attempt to access beyond end of device
[ 10.464578] sr0: rw=0, want=149472, limit=149464
[ 10.464592] Buffer I/O error on dev sr0, logical block 18683, async page read
[ 10.505095] sr 1:0:0:0: [sr0] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[ 10.505119] sr 1:0:0:0: [sr0] tag#0 Sense Key : 0x3 [current]
[ 10.505133] sr 1:0:0:0: [sr0] tag#0 ASC=0x11 ASCQ=0x0
[ 10.505151] sr 1:0:0:0: [sr0] tag#0 CDB: opcode=0x28 28 00 00 00 90 80 00 00 3c 00
[ 10.505169] blk_update_request: critical medium error, dev sr0, sector 147968 op 0x0:(READ) flags 0x80700 phys_seg 16 prio class 0
[ 10.510185] sr 1:0:0:0: [sr0] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[ 10.510209] sr 1:0:0:0: [sr0] tag#0 Sense Key : 0x3 [current]
[ 10.510224] sr 1:0:0:0: [sr0] tag#0 ASC=0x11 ASCQ=0x0
[ 10.510242] sr 1:0:0:0: [sr0] tag#0 CDB: opcode=0x28 28 00 00 00 90 80 00 00 02 00
[ 10.510260] blk_update_request: critical medium error, dev sr0, sector 147968 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 10.510276] Buffer I/O error on dev sr0, logical block 18496, async page read
[ 10.515427] sr 1:0:0:0: [sr0] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[ 10.515449] sr 1:0:0:0: [sr0] tag#0 Sense Key : 0x3 [current]
[ 10.515464] sr 1:0:0:0: [sr0] tag#0 ASC=0x11 ASCQ=0x0
[ 10.515482] sr 1:0:0:0: [sr0] tag#0 CDB: opcode=0x28 28 00 00 00 91 f4 00 00 02 00
[ 10.515500] blk_update_request: critical medium error, dev sr0, sector 149456 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 10.515576] attempt to access beyond end of device
[ 10.515588] sr0: rw=0, want=149464, limit=149456
[ 10.515602] Buffer I/O error on dev sr0, logical block 18682, async page read
[ 10.558498] sr 1:0:0:0: [sr0] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[ 10.558521] sr 1:0:0:0: [sr0] tag#0 Sense Key : 0x3 [current]
[ 10.558535] sr 1:0:0:0: [sr0] tag#0 ASC=0x11 ASCQ=0x0
[ 10.558553] sr 1:0:0:0: [sr0] tag#0 CDB: opcode=0x28 28 00 00 00 91 f0 00 00 02 00
[ 10.558571] blk_update_request: critical medium error, dev sr0, sector 149440 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 10.558634] attempt to access beyond end of device
[ 10.558647] sr0: rw=0, want=149448, limit=149440
[ 10.558661] Buffer I/O error on dev sr0, logical block 18680, async page read
[ 10.589540] sr 1:0:0:0: [sr0] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[ 10.589565] sr 1:0:0:0: [sr0] tag#0 Sense Key : 0x3 [current]
[ 10.589580] sr 1:0:0:0: [sr0] tag#0 ASC=0x11 ASCQ=0x0
[ 10.589597] sr 1:0:0:0: [sr0] tag#0 CDB: opcode=0x28 28 00 00 00 90 80 00 00 3c 00
[ 10.589616] blk_update_request: critical medium error, dev sr0, sector 147968 op 0x0:(READ) flags 0x80700 phys_seg 3 prio class 0
[ 10.594394] Buffer I/O error on dev sr0, logical block 18496, async page read
[ 10.599561] attempt to access beyond end of device
[ 10.599579] sr0: rw=0, want=149440, limit=149432
[ 10.599593] Buffer I/O error on dev sr0, logical block 18679, async page read
[ 13.141948] uart-pl011 3f201000.serial: no DMA platform data
[ 13.636828] 8021q: 802.1Q VLAN Support v1.8
[ 14.276998] Adding 102396k swap on /var/swap. Priority:-2 extents:5 across:143356k FS
[ 15.144470] 8021q: adding VLAN 0 to HW filter on device eth0
