Pour une raison inconnue, mon RPi4 (dernière version de Raspbian) s’est arrêté hier soir lors d’une mise à jour sans surveillance (unattended upgrade). Les traces les plus récentes que j’ai trouvées dans /var/log sont:
pi@raspberrypi:~ $ tail /media/pi/ROOT/var/log/unattended-upgrades/unattended-upgrades.log
2020-04-13 04:08:04,863 INFO Initial whitelist:
2020-04-13 04:08:04,864 INFO Démarrage du script de mise à niveau automatique
2020-04-13 04:08:04,864 INFO Les origines permises sont: o=Debian,n=buster, o=deb.sury.org,n=buster, o=Raspberry Pi Foundation,n=buster, o=Raspbian,n=stretch,l=Raspbian, origin=Debian,codename=buster-updates, origin=Debian,codename=buster-proposed-updates, origin=Debian,codename=buster,label=Debian, origin=Debian,codename=buster,label=Debian-Security
2020-04-13 06:47:48,301 INFO Checking if system is running on battery is skipped. Please install powermgmt-base package to check power status and skip installing updates when the system is running on battery.
2020-04-13 06:47:48,345 INFO Initial blacklist :
2020-04-13 06:47:48,346 INFO Initial whitelist:
2020-04-13 06:47:48,347 INFO Démarrage du script de mise à niveau automatique
2020-04-13 06:47:48,348 INFO Les origines permises sont: o=Debian,n=buster, o=deb.sury.org,n=buster, o=Raspberry Pi Foundation,n=buster, o=Raspbian,n=stretch,l=Raspbian, origin=
2020-04-13 06:48:06,090 INFO Paquets mis à niveau: fonts-opensymbol libreoffice libreoffice-avmedia-backend-gstreamer libreoffice-base libreoffice-base-core libreoffice-base-dri
vers libreoffice-calc libreoffice-common libreoffice-core libreoffice-draw libreoffice-impress libreoffice-java-common libreoffice-math libreoffice-report-builder-bin libreoffic
e-sdbc-firebird libreoffice-sdbc-hsqldb libreoffice-style-colibre libreoffice-style-tango libreoffice-writer python3-uno rpi-eeprom rpi-eeprom-images uno-libs3 ure
2020-04-13 06:48:06,091 INFO Writing dpkg log to /var/log/unattended-upgrades/unattended-upgrades-dpkg.log
ou encore:
pi@raspberrypi:~ $ tail /media/pi/ROOT/var/log/dpkg.log
2020-04-13 06:48:26 status half-configured libreoffice-draw:armhf 1:6.1.5-3+rpi1+deb10u5
2020-04-13 06:48:26 status unpacked libreoffice-draw:armhf 1:6.1.5-3+rpi1+deb10u5
2020-04-13 06:48:26 status half-installed libreoffice-draw:armhf 1:6.1.5-3+rpi1+deb10u5
2020-04-13 06:48:26 status unpacked libreoffice-draw:armhf 1:6.1.5-3+rpi1+deb10u5+rpt1
2020-04-13 06:48:27 upgrade python3-uno:armhf 1:6.1.5-3+rpi1+deb10u5 1:6.1.5-3+rpi1+deb10u5+rpt1
2020-04-13 06:48:27 status half-configured python3-uno:armhf 1:6.1.5-3+rpi1+deb10u5
2020-04-13 06:48:27 status unpacked python3-uno:armhf 1:6.1.5-3+rpi1+deb10u5
2020-04-13 06:48:27 status half-installed python3-uno:armhf 1:6.1.5-3+rpi1+deb10u5
2020-04-13 06:48:27 status unpacked python3-uno:armhf 1:6.1.5-3+rpi1+deb10u5+rpt1
Et d’autres à 6h48, toutes liées à la mise à niveau. Donc pas de problème évident…
Malheureusement, quand j’essaie de redémarrer le Pi, je reçois :
kernel panic - not syncing: Attempted to kill init! exitcode=0x00000007
Je ne peux pas voir le « vrai » message avant celui-ci car il défile très vite et je ne trouve aucun journal.
Ma configuration démarre sur un disque dur (configuré dans cmdline.txt) donc je l’ai changée pour démarrer sur la carte SD et là, tout fonctionne bien ==> la carte SD elle-même n’a aucun problème…
Dans cette configuration, le disque dur est monté automatiquement sur /media/pi/ROOT, je peux le lire sans aucun problème, et j’ai vérifié avec fsck.ext4 qui m’a dit qu’il était ok. (vérifié aussi sur une autre machine linux)
$ sudo fsck.ext4 -y /dev/sda1
e2fsck 1.44.5 (15-Dec-2018)
ROOT: clean, 418057/1835008 files, 3114608/7325696 blocks
Si vous avez une idée pour me sortir de là, je suis grave dans la m… j’ai 3 serveurs web, mon serveur de mail, mon nextcloud, … dessus.
Merci d’avance!
