Depuis ce matin 04-06-2019 je n ai plus aucune synchronisation avec les serveurs ntp / debian
j ai repris les config sans succès - le problème existe tous mes Raspberry en ligne
j ai fouillé partout sur le net sans un fil intéréssant …
sur différentes ip wan
root@raspberrypi:~# ntpdate -buv 0.debian.pool.ntp.org
28 May 18:31:50 ntpdate[3232]: ntpdate 4.2.8p10@1.3728-o Sat Mar 10 18:03:47 UTC 2018 (1)
28 May 18:31:59 ntpdate[3232]: no server suitable for synchronization found
et la ou je suis perdu
root@raspberrypi:~# ntpdate -d 0.debian.pool.ntp.org
28 May 18:39:59 ntpdate[3301]: ntpdate 4.2.8p10@1.3728-o Sat Mar 10 18:03:47 UTC 2018 (1)
transmit(62.210.244.146)
transmit(51.255.141.154)
transmit(5.135.3.88)
transmit(129.250.35.250)
62.210.244.146: Server dropped: no data
51.255.141.154: Server dropped: no data
5.135.3.88: Server dropped: no data
129.250.35.250: Server dropped: no data
server 62.210.244.146, port 123
stratum 0, precision 0, leap 00, trust 000
refid [62.210.244.146], delay 0.00000, dispersion 64.00000
transmitted 4, in filter 4
reference time: 00000000.00000000 Thu, Feb 7 2036 7:28:16.000
originate timestamp: 00000000.00000000 Thu, Feb 7 2036 7:28:16.000
transmit timestamp: e097e2e5.989d3eef Tue, May 28 2019 18:40:05.596
filter delay: 0.00000 0.00000 0.00000 0.00000
filter offset: 0.000000 0.000000 0.000000 0.000000
offset 0.000000
server 51.255.141.154, port 123
refid [51.255.141.154], delay 0.00000, dispersion 64.00000
transmit timestamp: e097e2e5.cbcc3cb8 Tue, May 28 2019 18:40:05.796
offset 0.000000
server 5.135.3.88, port 123
refid [5.135.3.88], delay 0.00000, dispersion 64.00000
transmit timestamp: e097e2e5.feffee9e Tue, May 28 2019 18:40:05.996
offset 0.000000
server 129.250.35.250, port 123
refid [129.250.35.250], delay 0.00000, dispersion 64.00000
transmit timestamp: e097e2e6.32334925 Tue, May 28 2019 18:40:06.196
offset 0.000000
28 May 18:40:08 ntpdate[3301]: no server suitable for synchronization found
je n ai aucun retour d’info ?
quelqu’un a t il une solution
