Bonjour, j’ai un souci avec motion et plusieurs caméras, j’utilise une webcam et une pi cam. la webcam fonctionne mais pas la pi cam avec motion. la pi cam fonctionne très bien en photo et vidéo en dehors de motion.
j’ai les logs d’erreur suivant:
[1:ml1] [NTC] [VID] [Aug 10 15:22:40] v4l2_set_pix_format: (9) NV12 (Y/CbCr 4:2:0)
[1:ml1] [NTC] [VID] [Aug 10 15:22:40] v4l2_set_pix_format: 9 - Y/CbCr 4:2:0 (compressed : 0) (0x3231564e)
[1:ml1] [NTC] [VID] [Aug 10 15:22:40] v4l2_set_pix_format: (10) BGR3 (24-bit BGR 8-8-8)
[1:ml1] [NTC] [VID] [Aug 10 15:22:40] v4l2_set_pix_format: 10 - 24-bit BGR 8-8-8 (compressed : 0) (0x33524742)
[1:ml1] [NTC] [VID] [Aug 10 15:22:40] v4l2_set_pix_format: (11) YV12 (Planar YVU 4:2:0)
[1:ml1] [NTC] [VID] [Aug 10 15:22:40] v4l2_set_pix_format: 11 - Planar YVU 4:2:0 (compressed : 0) (0x32315659)
[1:ml1] [NTC] [VID] [Aug 10 15:22:40] v4l2_set_pix_format: (12) NV21 (Y/CrCb 4:2:0)
[1:ml1] [NTC] [VID] [Aug 10 15:22:40] v4l2_set_pix_format: 12 - Y/CrCb 4:2:0 (compressed : 0) (0x3132564e)
[1:ml1] [NTC] [VID] [Aug 10 15:22:40] v4l2_set_pix_format: (13) BGR4 (32-bit BGRA/X 8-8-8-8)
[1:ml1] [NTC] [VID] [Aug 10 15:22:40] v4l2_set_pix_format: 13 - 32-bit BGRA/X 8-8-8-8 (compressed : 0) (0x34524742)
[1:ml1] [NTC] [VID] [Aug 10 15:22:40] v4l2_set_pix_format Selected palette YU12
[1:ml1] [NTC] [VID] [Aug 10 15:22:40] v4l2_do_set_pix_format: Testing palette YU12 (640x480)
[1:ml1] [ERR] [VID] [Aug 10 15:22:40] v4l2_do_set_pix_format: Error setting pixel format.
VIDIOC_S_FMT: : Device or resource busy
[1:ml1] [ERR] [VID] [Aug 10 15:22:40] VIDIOC_TRY_FMT failed for format v4l2_set_pix_format: Device or resource busy
[1:ml1] [ERR] [VID] [Aug 10 15:22:40] v4l2_set_pix_format: Unable to find a compatible palette format.
[1:ml1] [NTC] [VID] [Aug 10 15:22:40] vid_v4lx_start: Using V4L1
[1:ml1] [ERR] [ALL] [Aug 10 15:22:40] motion_loop: Video device fatal error - Closing video device
[1:ml1] [NTC] [VID] [Aug 10 15:22:40] vid_close: Closing video device /dev/video0
[1:ml1] [NTC] [VID] [Aug 10 15:22:40] v4l2_set_control: setting control « Brightness » to 50 (ret 0 )
[1:ml1] [ERR] [ALL] [Aug 10 15:22:40] decode_jpeg_raw: Input is interlaced but no interlacing set
[1:ml1] [ERR] [ALL] [Aug 10 15:22:42] motion_init: Error capturing first image
[1:ml1] [NTC] [STR] [Aug 10 15:22:42] http_bindsock: error binding on any IPv4 address port 8087
[1:ml1] [ERR] [ALL] [Aug 10 15:22:42] motion_init: Problem enabling motion-stream server in port 8087: Address already in use
[1:ml1] [NTC] [ALL] [Aug 10 15:22:42] motion_loop: Thread exiting
[1:ml1] [NTC] [VID] [Aug 10 15:22:42] vid_close: Closing video device /dev/video0
Quand je me connecte au port de la pi cam, j’ai un écran noir/gris, même avec plus de lumière, pas de changement!
Quelqu’un aurait une solution?
