Impossible de me connecter en wifi sur pi3 model B v1.2 avec la version Bullseye (version 11).
config activer dans wpa_supplicant.conf
Pouvez-vous m’aider? Merci
voici les messages d’erreurs dans kern.log:
Feb  8 10:56:53 pitest kernel: [   10.906031] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Jul 19 2021 03:24:18 version 7.45.98 (TOB) (56df937 CY) FWID 01-8e14b897Feb  8 10:56:53 pitest kernel: [   11.031490] brcmfmac: brcmf_sdio_bus_sleep: error while changing bus sleep state -110
Feb  8 10:56:53 pitest kernel: [   11.031603] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Feb  8 10:56:53 pitest kernel: [   11.032008] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Feb  8 10:56:53 pitest kernel: [   11.032310] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Feb  8 10:56:53 pitest kernel: [   11.032550] brcmfmac: brcmf_sdio_dpc: sdio ctrlframe tx failed err=-110
Feb  8 10:56:53 pitest kernel: [   11.032581] brcmfmac: brcmf_sdio_dpc: failed backplane access over SDIO, halting operation
Feb  8 10:56:53 pitest kernel: [   11.032613] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Feb  8 10:56:53 pitest kernel: [   11.032634] ieee80211 phy0: brcmf_cfg80211_get_channel: chanspec failed (-110)
Feb  8 10:56:53 pitest kernel: [   11.208879] sd 0:0:0:0: Attached scsi generic sg0 type 0
Feb  8 10:56:53 pitest kernel: [   11.536200] brcmfmac: brcmf_sdio_bus_sleep: error while changing bus sleep state -110
