bonjour
merci de ton aide
j’ai deja fait plusieures fois cette manip et ca marche pas
tiens regarde les captures d’ecran
root@raspberrypi:/home/pi# nmcli con
NAME UUID TYPE DEVICE
wifiap 9ff8a51f-5c8a-4d05-a6ed-37dd2e9b6cb7 wifi --
J’efface les connections existantes et je me reconnecte
root@raspberrypi:/home/pi# nmcli con delete wifiap
Connection 'wifiap' (9ff8a51f-5c8a-4d05-a6ed-37dd2e9b6cb7) successfully deleted.
root@raspberrypi:/home/pi# nmcli dev wifi con "wifiap" password "testpassword"
Error: Connection activation failed: (7) Secrets were required, but not provided.
wifiap 152649e8-1eec-4418-94a9-889f254f7296 wifi --
root@raspberrypi:/home/pi# nmcli con show "wifiap"
connection.id: wifiap
connection.uuid: 152649e8-1eec-4418-94a9-889f254f7296
connection.stable-id: --
connection.type: 802-11-wireless
connection.interface-name: --
connection.autoconnect: yes
connection.autoconnect-priority: 0
connection.autoconnect-retries: -1 (default)
connection.multi-connect: 0 (default)
connection.auth-retries: -1
connection.timestamp: 0
connection.read-only: no
connection.permissions: --
connection.zone: --
connection.master: --
connection.slave-type: --
connection.autoconnect-slaves: -1 (default)
connection.secondaries: --
connection.gateway-ping-timeout: 0
connection.metered: unknown
connection.lldp: default
connection.mdns: -1 (default)
connection.llmnr: -1 (default)
802-11-wireless.ssid: wifiap
802-11-wireless.mode: infrastructure
802-11-wireless.band: --
802-11-wireless.channel: 0
802-11-wireless.bssid: --
802-11-wireless.rate: 0
802-11-wireless.tx-power: 0
802-11-wireless.mac-address: DC:A6:32:68:5A:B0
802-11-wireless.cloned-mac-address: --
802-11-wireless.generate-mac-address-mask:--
802-11-wireless.mac-address-blacklist: --
802-11-wireless.mac-address-randomization:default
802-11-wireless.mtu: auto
802-11-wireless.seen-bssids: --
802-11-wireless.hidden: no
802-11-wireless.powersave: 0 (default)
802-11-wireless.wake-on-wlan: 0x1 (default)
802-11-wireless-security.key-mgmt: wpa-psk
802-11-wireless-security.wep-tx-keyidx: 0
802-11-wireless-security.auth-alg: open
802-11-wireless-security.proto: --
802-11-wireless-security.pairwise: --
802-11-wireless-security.group: --
802-11-wireless-security.pmf: 0 (default)
802-11-wireless-security.leap-username: --
802-11-wireless-security.wep-key0: <hidden>
802-11-wireless-security.wep-key1: <hidden>
802-11-wireless-security.wep-key2: <hidden>
802-11-wireless-security.wep-key3: <hidden>
802-11-wireless-security.wep-key-flags: 0 (none)
802-11-wireless-security.wep-key-type: unknown
802-11-wireless-security.psk: <hidden>
802-11-wireless-security.psk-flags: 0 (none)
802-11-wireless-security.leap-password: <hidden>
802-11-wireless-security.leap-password-flags:0 (none)
802-11-wireless-security.wps-method: 0 (default)
802-11-wireless-security.fils: 0 (default)
ipv4.method: auto
ipv4.dns: --
ipv4.dns-search: --
ipv4.dns-options: ""
ipv4.dns-priority: 0
ipv4.addresses: --
ipv4.gateway: --
ipv4.routes: --
ipv4.route-metric: -1
ipv4.route-table: 0 (unspec)
ipv4.ignore-auto-routes: no
ipv4.ignore-auto-dns: no
ipv4.dhcp-client-id: --
ipv4.dhcp-timeout: 0 (default)
ipv4.dhcp-send-hostname: yes
ipv4.dhcp-hostname: --
ipv4.dhcp-fqdn: --
ipv4.never-default: no
ipv4.may-fail: yes
ipv4.dad-timeout: -1 (default)
ipv6.method: auto
ipv6.dns: --
ipv6.dns-search: --
ipv6.dns-options: ""
ipv6.dns-priority: 0
ipv6.addresses: --
ipv6.gateway: --
ipv6.routes: --
ipv6.route-metric: -1
ipv6.route-table: 0 (unspec)
ipv6.ignore-auto-routes: no
ipv6.ignore-auto-dns: no
ipv6.never-default: no
ipv6.may-fail: yes
ipv6.ip6-privacy: -1 (unknown)
ipv6.addr-gen-mode: stable-privacy
ipv6.dhcp-duid: --
ipv6.dhcp-send-hostname: yes
ipv6.dhcp-hostname: --
ipv6.token: --
proxy.method: none
proxy.browser-only: no
proxy.pac-url: --
proxy.pac-script: --
root@raspberrypi:/home/pi# ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.4 netmask 255.255.255.0 broadcast 192.168.1.255
ether dc:a6:32:68:5a:af txqueuelen 1000 (Ethernet)
RX packets 472969 bytes 31381679 (29.9 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 16399 bytes 1758010 (1.6 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
loop txqueuelen 1000 (Local Loopback)
RX packets 1097 bytes 76148 (74.3 KiB)
TX packets 1097 bytes 76148 (74.3 KiB)
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 2a:84:5e:30:9e:2d txqueuelen 1000 (Ethernet)
RX packets 147 bytes 22479 (21.9 KiB)
TX packets 108 bytes 14250 (13.9 KiB)
wlan0: disconnected
"Broadcom BCM43438 combo and Bluetooth Low Energy"
1 connection available
wifi (brcmfmac), 2A:84:5E:30:9E:2D, hw, mtu 1500
eth0: unmanaged
"eth0"
ethernet (bcmgenet), DC:A6:32:68:5A:AF, hw, mtu 1500
lo: unmanaged
"lo"
loopback (unknown), 00:00:00:00:00:00, sw, mtu 65536
Use "nmcli device show" to get complete information about known devices and
"nmcli connection show" to get an overview on active connection profiles.
Consult nmcli(1) and nmcli-examples(5) manual pages for complete usage details.
root@raspberrypi:/home/pi# nmcli wlan0
Error: argument 'wlan0' not understood. Try passing --help instead.
root@raspberrypi:/home/pi# nmcli connection show
root@raspberrypi:/home/pi# nmcli device show
GENERAL.DEVICE: wlan0
GENERAL.TYPE: wifi
GENERAL.HWADDR: 2A:84:5E:30:9E:2D
GENERAL.MTU: 1500
GENERAL.STATE: 30 (disconnected)
GENERAL.CONNECTION: --
GENERAL.CON-PATH: --
GENERAL.DEVICE: eth0
GENERAL.TYPE: ethernet
GENERAL.HWADDR: DC:A6:32:68:5A:AF
GENERAL.MTU: 1500
GENERAL.STATE: 10 (unmanaged)
WIRED-PROPERTIES.CARRIER: on
IP4.ADDRESS[1]: 192.168.1.4/24
IP4.GATEWAY: 192.168.1.254
IP4.ROUTE[1]: dst = 0.0.0.0/0, nh = 192.168.1.254, mt = 0
IP4.ROUTE[2]: dst = 192.168.1.0/24, nh = 0.0.0.0, mt = 0
IP6.GATEWAY: --
GENERAL.DEVICE: lo
GENERAL.TYPE: loopback
GENERAL.HWADDR: 00:00:00:00:00:00
GENERAL.MTU: 65536
IP4.ADDRESS[1]: 127.0.0.1/8
IP4.GATEWAY: --
IP6.GATEWAY: --
J’ai besoin d’aide
