J’ai acheter le rpi5 8 Go, j’ai installer le système sur la carte sd Raspberry Pi os Full x64 (2.7 Go) Publié le 05-12-2023, tout fonctionne sauf minidlna.
serveur@RPI-5:~ $ sudo systemctl status minidlna
● minidlna.service - MiniDLNA lightweight DLNA/UPnP-AV server
Loaded: loaded (/lib/systemd/system/minidlna.service; enabled; preset: enabled)
Active: active (running) since Tue 2024-01-30 00:23:41 CET; 19h ago
Docs: man:minidlnad(1)
man:minidlna.conf(5)
Main PID: 779 (minidlnad)
Tasks: 2 (limit: 9246)
CPU: 183ms
CGroup: /system.slice/minidlna.service
└─779 /usr/sbin/minidlnad -f /etc/minidlna.conf -P /run/minidlna/minidlna.pid -S -r
janv. 30 00:23:41 RPI-5 systemd[1]: Started minidlna.service - MiniDLNA lightweight DLNA/UPnP-AV server.
janv. 30 00:23:42 RPI-5 minidlnad[779]: [2024/01/30 00:23:42] minidlna.c:670: error: Media directory "V,/home/serveur/Videos" not accessible [Permission denied]
janv. 30 00:23:42 RPI-5 minidlnad[779]: [2024/01/30 00:23:42] minidlna.c:670: error: Media directory "P,/home/serveur/Pictures" not accessible [Permission denied]
janv. 30 00:23:42 RPI-5 minidlnad[779]: [2024/01/30 00:23:42] minidlna.c:670: error: Media directory "A,/home/serveur/Music" not accessible [Permission denied]
serveur@RPI-5:~ $
Pourtant les droits sont correct
serveur@RPI-5:~ $ ls -alh $HOME
total 11M
drwx------ 31 serveur serveur 4,0K 30 janv. 00:23 .
drwxr-xr-x 3 root root 4,0K 5 déc. 06:26 ..
drwxr-xr-x 2 serveur serveur 4,0K 29 janv. 21:20 Music
drwxr-xr-x 3 serveur serveur 4,0K 29 janv. 21:20 Pictures
drwxr-xr-x 3 serveur serveur 4,0K 29 janv. 21:10 Videos
serveur@RPI-5:~ $
le fichier /etc/minidlna.conf
serveur@RPI-5:~ $ cat /etc/minidlna.conf
# This is the configuration file for the MiniDLNA daemon, a DLNA/UPnP-AV media
# server.
# Unless otherwise noted, the commented out options show their default value.
# On Debian, you can also refer to the minidlna.conf(5) man page for
# documentation about this file.
# Specify the user name or uid to run as (root by default).
# On Debian system command line option (from /etc/default/minidlna) overrides this.
#user=minidlna
# Path to the directory you want scanned for media files.
# This option can be specified more than once if you want multiple directories
# scanned.
# If you want to restrict a media_dir to a specific content type, you can
# prepend the directory name with a letter representing the type (A, P or V),
# followed by a comma, as so:
# * "A" for audio (eg. media_dir=A,/var/lib/minidlna/music)
# * "P" for pictures (eg. media_dir=P,/var/lib/minidlna/pictures)
# * "V" for video (eg. media_dir=V,/var/lib/minidlna/videos)
# * "PV" for pictures and video (eg. media_dir=PV,/var/lib/minidlna/digital_camera)
#media_dir=/var/lib/minidlna
media_dir=V,/home/serveur/Videos
media_dir=P,/home/serveur/Pictures
media_dir=A,/home/serveur/Music
#media_dir=PV,/var/lib/minidlna/digital_camera
# Set this to merge all media_dir base contents into the root container
# (The default is no.)
#merge_media_dirs=no
# Path to the directory that should hold the database and album art cache.
#db_dir=/var/cache/minidlna
# Path to the directory that should hold the log file.
#log_dir=/var/log/minidlna
# Type and minimum level of importance of messages to be logged.
# The types are "artwork", "database", "general", "http", "inotify",
# "metadata", "scanner", "ssdp" and "tivo".
# The levels are "off", "fatal", "error", "warn", "info" or "debug".
# "off" turns of logging entirely, "fatal" is the highest level of importance
# and "debug" the lowest.
# The types are comma-separated, followed by an equal sign ("="), followed by a
# level that applies to the preceding types. This can be repeated, separating
# each of these constructs with a comma.
# The default is to log all types of messages at the "warn" level.
#log_level=general,artwork,database,inotify,scanner,metadata,http,ssdp,tivo=warn
# Use a different container as the root of the directory tree presented to
# clients. The possible values are:
# * "." - standard container
# * "B" - "Browse Directory"
# * "M" - "Music"
# * "P" - "Pictures"
# * "V" - "Video"
# * Or, you can specify the ObjectID of your desired root container
# (eg. 1$F for Music/Playlists)
# If you specify "B" and the client device is audio-only then "Music/Folders"
# will be used as root.
#root_container=.
# Network interface(s) to bind to (e.g. eth0), comma delimited.
# This option can be specified more than once.
#network_interface=
# Port number for HTTP traffic (descriptions, SOAP, media transfer).
# This option is mandatory (or it must be specified on the command-line using
# "-p").
port=8200
# URL presented to clients (e.g. http://example.com:80).
#presentation_url=/
# Name that the DLNA server presents to clients.
# Defaults to "hostname: username".
#friendly_name=
# Serial number the server reports to clients.
# Defaults to the MAC address of nework interface.
#serial=
# Model name the server reports to clients.
#model_name=Windows Media Connect compatible (MiniDLNA)
# Model number the server reports to clients.
# Defaults to the version number of minidlna.
#model_number=
# Automatic discovery of new files in the media_dir directory.
#inotify=yes
# List of file names to look for when searching for album art.
# Names should be delimited with a forward slash ("/").
album_art_names=Cover.jpg/cover.jpg/AlbumArtSmall.jpg/albumartsmall.jpg
album_art_names=AlbumArt.jpg/albumart.jpg/Album.jpg/album.jpg
album_art_names=Folder.jpg/folder.jpg/Thumb.jpg/thumb.jpg
# Strictly adhere to DLNA standards.
# This allows server-side downscaling of very large JPEG images, which may
# decrease JPEG serving performance on (at least) Sony DLNA products.
#strict_dlna=no
# Support for streaming .jpg and .mp3 files to a TiVo supporting HMO.
#enable_tivo=no
# Which method to use for registering in TiVo: 'bonjour' (default) or
# legacy 'beacon'
#tivo_discovery=bonjour
# SSDP notify interval, in seconds.
#notify_interval=895
# Path to the MiniSSDPd socket, for MiniSSDPd support.
#minissdpdsocket=/run/minissdpd.sock
# Always set SortCriteria to this value, regardless of the SortCriteria
# passed by the client
# e.g. force_sort_criteria=+upnp:class,+upnp:originalTrackNumber,+dc:title
#force_sort_criteria=
# maximum number of simultaneous connections
# note: many clients open several simultaneous connections while streaming
#max_connections=50
# set this to yes to allow symlinks that point outside user-defined media_dirs.
#wide_links=no
serveur@RPI-5:~ $
Extrait de /var/log/minidlna/minidlna.log
serveur@RPI-5:~ $ cat /var/log/minidlna/minidlna.log
minidlna.c:1126: warn: Starting MiniDLNA version 1.3.0.
minidlna.c:393: warn: Creating new database at /var/cache/minidlna/files.db
minidlna.c:1186: warn: HTTP listening on port 8200
scanner.c:730: warn: Scanning /var/lib/minidlna
scanner.c:819: warn: Scanning /var/lib/minidlna finished (0 files)!
playlist.c:135: warn: Parsing playlists...
playlist.c:269: warn: Finished parsing playlists.
monitor.c:222: warn: WARNING: Inotify max_user_watches [63364] is low or close to the number of used watches [0] and I do not have permission to increase this limit. Please do so manually by writing a higher value into /proc/sys/fs/inotify/max_user_watches.
minidlna.c:200: warn: received signal 15, good-bye
upnphttp.c:1094: error: recv (state0): Connexion ré-initialisée par le correspondant
serveur@RPI-5:~ $
serveur@RPI-5:~ $ cat /proc/sys/fs/inotify/max_user_watches
63364
serveur@RPI-5:~ $
serveur@RPI-5:~ $ df -h
Sys. de fichiers Taille Utilisé Dispo Uti% Monté sur
udev 3,8G 0 3,8G 0% /dev
tmpfs 805M 6,2M 799M 1% /run
/dev/mmcblk0p2 29G 20G 7,7G 72% /
tmpfs 4,0G 608K 4,0G 1% /dev/shm
tmpfs 5,0M 64K 5,0M 2% /run/lock
/dev/mmcblk0p1 510M 73M 438M 15% /boot/firmware
tmpfs 805M 224K 805M 1% /run/user/1000
serveur@RPI-5:~ $
serveur@RPI-5:~ $ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
mmcblk0 179:0 0 29,7G 0 disk
├─mmcblk0p1 179:1 0 512M 0 part /boot/firmware
└─mmcblk0p2 179:2 0 29,2G 0 part /
serveur@RPI-5:~ $
serveur@RPI-5:~ $ sudo parted -l /dev/mmcblk0
Model: SD SK32G (sd/mmc)
Disk /dev/mmcblk0: 31,9GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 4194kB 541MB 537MB primary fat32 lba
2 541MB 31,9GB 31,4GB primary ext4
serveur@RPI-5:~ $
D’ou vient le problème, l’installation est fraiche ?
Merci d’avance pour vos avis et conseils
