je voudrai installer jdownloader sur mon Raspberry Pi Model B Rev 2 - raspian lite 32Bits.
J’ai réussi a installer une version de java 11 adaptée a mon pi (armv6). grace a ce tuto :
Mais quand je passe à l’installation de jdownloader, j’obtiens une flopée d’infos et d’erreurs et je ne sais pas lesquelles sont importantes et ce que je dois corriger pour réussir l’installation qui n’aboutit pas.
Si quelqu’un peut m’aider a y voir plus clair ou a un tuto a me fournir pour reussir mon installation…
D’avance merci.
FredPiTorrent@FredPiTorrent:~ $ java -jar JDownloader.jar -norestart
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by org.appwork.utils.ReflectionUtils (file:/home/FredPiTorrent/JDownloader.jar) to field java.io.PrintStream.charOut
WARNING: Please consider reporting this to the maintainers of org.appwork.utils.ReflectionUtils
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
INFO >> [sun.Desktop: null, XDG_CURRENT_DESKTOP: null, XDG_SESSION_TYPE: tty, KDE_FULL_SESSION: null, KDE_SESSION_VERSION: null, DESKTOP_SESSION: null, GNOME_DESKTOP_SESSION_ID: null, linuxFileOpen:null, linuxBrowseUrl:null]
INFO >> Prefer (merged) JSon Storage from File: /home/FredPiTorrent/cfg/org.appwork.utils.logging2.LogConfig.json
THREAD: 1
1|Log.L.log 04/04/2023, 14:14:00 - INFO [ org.appwork.loggingv3.LogV3(info) ] -> Application Root: /home/FredPiTorrent
SystemEntropyWorkaround:false
Multiple LogControllers Detected: org.appwork.utils.logging2.extmanager.LoggerFactory|Mode:NORMAL
Multiple LogControllers Detected: org.jdownloader.logging.LogController|org.jdownloader.logging.LogController@18ba8c8
1|Log.L.log 04/04/2023, 14:14:03 - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> Prefer (merged) JSon Storage from File: /home/FredPiTorrent/cfg/org.jdownloader.update.lastchance.LastChanceConfig.json
THREAD: 1
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:03 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: awt.toolkit: sun.awt.X11.XToolkit
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:03 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.specification.version: 11
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:03 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.cpu.isalist:
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:03 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: classloader_00000001: org.jdownloader.update.launcher.CL2
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:03 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.jnu.encoding: UTF-8
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:03 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: classloader_00000000: org.jdownloader.update.launcher.ClassLoaderExtensionImpl
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:03 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: extlogmanager.avoidsystemclassloader.hack: org.jdownloader.updatev2.JDClassLoaderLauncher$JDCustomRootClassLoader@133c8f8
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:03 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.class.path: JDownloader.jar
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:03 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vm.vendor: Azul Systems, Inc.
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:03 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.arch.data.model: 32
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:03 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.util.Arrays.useLegacyMergeSort: true
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:03 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vendor.url: http://www.azulsystems.com/
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:03 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: user.timezone: Europe/Paris
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:03 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: os.name: Linux
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vm.specification.version: 11
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.java.launcher: SUN_STANDARD
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: user.country: GB
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.net.preferIPv6Addresses: system
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.boot.library.path: /usr/lib/jvm/zulu11.41.75-ca-jdk11.0.8-linux_aarch32hf/lib
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.java.command: JDownloader.jar -norestart
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.rmi.server.useCodebaseOnly: true
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: jdk.debug: release
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.cpu.endian: little
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: user.home: /home/FredPiTorrent
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: user.language: en
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: LOG_INIT_DONE: 2 instances
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.specification.vendor: Oracle Corporation
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.version.date: 2020-07-14
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.home: /usr/lib/jvm/zulu11.41.75-ca-jdk11.0.8-linux_aarch32hf
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: file.separator: /
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: line.separator:
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.specification.name: Java Platform API Specification
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vm.specification.vendor: Oracle Corporation
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: jdk.vendor.version: Zulu11.41+75-CA
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.awt.graphicsenv: sun.awt.X11GraphicsEnvironment
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: org.appwork.LoggerFactory: org.appwork.utils.logging2.LogSourceRedirector
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.management.compiler: HotSpot Client Compiler
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: com.sun.jndi.rmi.object.trustURLCodebase: false
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.runtime.version: 11.0.8+10-LTS
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: user.name: FredPiTorrent
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: path.separator: :
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: com.sun.jndi.cosnaming.object.trustURLCodebase: false
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: os.version: 6.1.19+
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.runtime.name: OpenJDK Runtime Environment
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: file.encoding: UTF-8
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vm.name: OpenJDK Client VM
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vendor.version: Zulu11.41+75-CA
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vendor.url.bug: http://www.azulsystems.com/support/
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.io.tmpdir: /tmp
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.version: 11.0.8
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: user.dir: /home/FredPiTorrent
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: os.arch: arm
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vm.specification.name: Java Virtual Machine Specification
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.awt.printerjob: sun.print.PSPrinterJob
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: k: 0dd0ecf7f742873d745106adea00b64a
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.os.patch.level: unknown
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.util.logging.manager: org.appwork.utils.logging2.extmanager.ExtLogManager
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.library.path: /usr/java/packages/lib:/lib:/usr/lib
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vm.info: mixed mode
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vendor: Azul Systems, Inc.
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vm.version: 11.0.8+10-LTS
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.arch.abi: gnueabihf
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: com.sun.jndi.ldap.object.trustURLCodebase: false
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.io.unicode.encoding: UnicodeLittle
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.class.version: 55.0
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: SHELL: /bin/bash
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: SSH_TTY: /dev/pts/1
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:04 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: SSH_CLIENT: 192.168.2.101 14385 22
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: OLDPWD: /usr/lib/jvm
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: TERM: xterm
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: MOTD_SHOWN: pam
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: USER: FredPiTorrent
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: LANG: en_GB.UTF-8
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XDG_SESSION_ID: 4
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XDG_SESSION_TYPE: tty
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: DISPLAY: localhost:11.0
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: SSH_CONNECTION: 192.168.2.101 14385 192.168.2.165 22
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: TEXTDOMAIN: Linux-PAM
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: LOGNAME: FredPiTorrent
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: NO_AT_BRIDGE: 1
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XDG_RUNTIME_DIR: /run/user/1000
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> AUTO_WRAPPED>
SysEnv: LS_COLORS: rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01
;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;3
5:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;
35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: PWD: /home/FredPiTorrent
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: SHLVL: 1
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: HOME: /home/FredPiTorrent
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: _: /usr/bin/java
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XDG_SESSION_CLASS: user
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> jar:file:/home/FredPiTorrent/JDownloader.jar!/version.nfo:
${updateclient.revision}
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:05 - INFO [ org.jdownloader.update.launcher.SecondLevelLauncher(init) ] -> Args: [-norestart]
1|org.jdownloader.updatev2.restart.LinuxRestarter.log 04/04/2023, 14:14:05 - INFO [ org.jdownloader.updatev2.restart.Restarter(<init>) ] -> Create Restarter
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:06 - INFO [ org.jdownloader.update.launcher.SecondLevelLauncher(init) ] -> Restart Controller init done in 569
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:06 - INFO [ org.jdownloader.update.launcher.SecondLevelLauncher(init) ] -> Parse Arguments
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:06 - INFO [ org.jdownloader.update.launcher.SecondLevelLauncher(init) ] -> Parameter Parse done in 46
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:06 - INFO [ org.jdownloader.update.launcher.SecondLevelLauncher(init) ] -> Single Instance Controller
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:08 - INFO [ org.jdownloader.update.launcher.SecondLevelLauncher(init) ] -> Single Instance init done in 2100
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 04/04/2023, 14:14:08 - INFO [ org.jdownloader.update.launcher.SecondLevelLauncher(init) ] -> Init UpdateManager
1|Log.L.log 04/04/2023, 14:14:08 - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> Prefer (merged) JSon Storage from File: /home/FredPiTorrent/cfg/org.jdownloader.updatev2.UpdateSettings.json
1|Log.L.log 04/04/2023, 14:14:10 - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> Load JSon Storage from Classpath url: jar:file:/home/FredPiTorrent/JDownloader.jar!/cfg/updateclient/Setup.json
1|Log.L.log 04/04/2023, 14:14:10 - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> Prefer (merged) JSon Storage from File: /home/FredPiTorrent/cfg/updateclient/Setup.json
1|Log.L.log 04/04/2023, 14:14:11 - FINER [ org.appwork.loggingv3.LogV3(finer) ] -> Init StorageHandler for Interface:org.appwork.updatesys.client.Setup|Path:/home/FredPiTorrent/cfg/updateclient/Setup
1|org.jdownloader.update.UpdateManager.log 04/04/2023, 14:14:11 - FINE [ org.jdownloader.update.UpdateManager(<init>) ] -> ClientSetup 940
THREAD: 19
19|Log.L.log 04/04/2023, 14:14:12 - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> Prefer (merged) JSon Storage from File: /home/FredPiTorrent/cfg/org.jdownloader.settings.InternetConnectionSettings.json
19|Log.L.log 04/04/2023, 14:14:12 - FINER [ org.appwork.loggingv3.LogV3(finer) ] -> Init StorageHandler for Interface:org.jdownloader.updatev2.InternetConnectionSettings|Path:/home/FredPiTorrent/cfg/org.jdownloader.settings.InternetConnectionSettings
19|Log.L.log 04/04/2023, 14:14:13 - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> Load JSon Storage from Classpath url: jar:file:/home/FredPiTorrent/JDownloader.jar!/cfg/updateclient/HttpSettings.json
19|Log.L.log 04/04/2023, 14:14:13 - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> CFG File does not exist: /home/FredPiTorrent/cfg/updateclient/HttpSettings.json
19|Log.L.log 04/04/2023, 14:14:13 - FINER [ org.appwork.loggingv3.LogV3(finer) ] -> Init StorageHandler for Interface:org.appwork.updatesys.client.defaultimpl.http.UpdateHttpClientOptions|Path:/home/FredPiTorrent/cfg/updateclient/HttpSettings
19|Log.L.log 04/04/2023, 14:14:14 - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> CFG File does not exist: /home/FredPiTorrent/cfg/ProxySelector.json
19|Log.L.log 04/04/2023, 14:14:14 - FINER [ org.appwork.loggingv3.LogV3(finer) ] -> Init StorageHandler for Interface:org.appwork.updatesys.client.defaultimpl.http.ProxySelectorSettings|Path:/home/FredPiTorrent/cfg/ProxySelector
19|Log.L.log 04/04/2023, 14:14:14 - FINER [ org.appwork.loggingv3.LogV3(finer) ] -> Read Config(File): /home/FredPiTorrent/cfg/ProxySelector.proxies.json
19|Log.L.log 04/04/2023, 14:14:16 - FINER [ org.appwork.loggingv3.LogV3(finer) ] -> Read Config(URL): jar:file:/home/FredPiTorrent/JDownloader.jar!/cfg/updateclient/Setup.updateservers.json
19|Log.L.log 04/04/2023, 14:14:16 - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> CFG File does not exist: /home/FredPiTorrent/update/versioninfo/JD/extensions.json
19|Log.L.log 04/04/2023, 14:14:16 - FINER [ org.appwork.loggingv3.LogV3(finer) ] -> Init StorageHandler for Interface:org.appwork.updatesys.client.extensions.ExtensionsStorage|Path:/home/FredPiTorrent/update/versioninfo/JD/extensions
THREAD: 19
19|org.jdownloader.update.UpdateManager.log 04/04/2023, 14:14:16 - INFO [ org.appwork.updatesys.client.extensions.ExtensionManager(init) ] -> Installed Extensions: []
19|org.jdownloader.update.UpdateManager.log 04/04/2023, 14:14:16 - INFO [ org.appwork.updatesys.client.extensions.ExtensionManager(init) ] -> Requested Extension Installations: []
19|org.jdownloader.update.UpdateManager.log 04/04/2023, 14:14:16 - INFO [ org.appwork.updatesys.client.extensions.ExtensionManager(init) ] -> Requested Extension Uninstalls: []
19|org.jdownloader.update.UpdateManager.log 04/04/2023, 14:14:16 - INFO [ org.jdownloader.update.JDUpdateClient$JDExtensionManager(init) ] -> Installed Extensions: []
19|org.jdownloader.update.UpdateManager.log 04/04/2023, 14:14:17 - INFO [ org.appwork.updatesys.client.FileList(<init>) ] -> FileList at /home/FredPiTorrent/update/versioninfo/JD/filelist.txt Size: 0
19|Log.L.log 04/04/2023, 14:14:17 - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> CFG File does not exist: /home/FredPiTorrent/cfg/org.appwork.updatesys.client.tracker.TrackConfig.json
THREAD: 1
1|org.jdownloader.update.UpdateManager.log 04/04/2023, 14:14:17 - FINE [ org.jdownloader.update.UpdateManager(<init>) ] -> Client 5653
19|Log.L.log 04/04/2023, 14:14:17 - INFO [ org.appwork.storage.JsonKeyValueStorage(<init>) ] -> CFG File does not exist: /home/FredPiTorrent/update/versioninfo/JDU/extensions.json
19|Log.L.log 04/04/2023, 14:14:17 - FINER [ org.appwork.loggingv3.LogV3(finer) ] -> Init StorageHandler for Interface:org.appwork.updatesys.client.extensions.ExtensionsStorage|Path:/home/FredPiTorrent/update/versioninfo/JDU/extensions
THREAD: 19
19|org.jdownloader.update.UpdateManager.log 04/04/2023, 14:14:17 - INFO [ org.appwork.updatesys.client.extensions.ExtensionManager(init) ] -> Installed Extensions: []
19|org.jdownloader.update.UpdateManager.log 04/04/2023, 14:14:18 - INFO [ org.appwork.updatesys.client.extensions.ExtensionManager(init) ] -> Requested Extension Installations: []
19|org.jdownloader.update.UpdateManager.log 04/04/2023, 14:14:18 - INFO [ org.appwork.updatesys.client.extensions.ExtensionManager(init) ] -> Requested Extension Uninstalls: []
19|org.jdownloader.update.UpdateManager.log 04/04/2023, 14:14:18 - INFO [ org.appwork.updatesys.client.FileList(<init>) ] -> FileList at /home/FredPiTorrent/update/versioninfo/JDU/filelist.txt Size: 0
je suis obligé de couper en deux, la suite ici:
