J’essaie d’installer le logiciel de mesure audio REW sur un RPi4 64bit Bullseye.
Le fichier d’installation est un .sh
manu@raspberrypi:~ $ wget https://www.roomeqwizard.com/installers/REW_linux_no_jre_5_31_3.sh
--2025-01-18 17:06:00--  https://www.roomeqwizard.com/installers/REW_linux_no_jre_5_31_3.sh
Resolving www.roomeqwizard.com (www.roomeqwizard.com)... 170.249.203.85
Connecting to www.roomeqwizard.com (www.roomeqwizard.com)|170.249.203.85|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 31882909 (30M) [application/x-sh]
Saving to: ‘REW_linux_no_jre_5_31_3.sh’
REW_linux_no_jre_5_31_3.sh 100%[=====================================>]  30.41M  7.62MB/s    in 4.6s
2025-01-18 17:06:05 (6.67 MB/s) - ‘REW_linux_no_jre_5_31_3.sh’ saved [31882909/31882909]
manu@raspberrypi:~ $ cd /home/manu/REW
manu@raspberrypi:~/REW $ sudo chmod +x /home/manu/REW/REW_linux_no_jre_5_31_3.sh
manu@raspberrypi:~/REW $ ./REW_linux_no_jre_5_31_3.sh
No suitable Java Virtual Machine could be found on your system.
The version of the JVM must be 1.8.
Please define INSTALL4J_JAVA_HOME to point to a suitable JVM.
manu@raspberrypi:~/REW $ cd
manu@raspberrypi:~ $ sudo update-alternatives --config java
There are 2 choices for the alternative java (providing /usr/bin/java).
  Selection    Path                                         Priority   Status
  0            /usr/lib/jvm/java-11-openjdk-arm64/bin/java   1111      auto mode
  1            /usr/lib/jvm/java-11-openjdk-arm64/bin/java   1111      manual mode
* 2            /usr/lib/jvm/java-17-oracle/bin/java          1091      manual mode
Press <enter> to keep the current choice[*], or type selection number:
J’ai modifé le fichier afin qu’il pointe vers Java:
#!/bin/sh
# Uncomment the following line to override the JVM search sequence
INSTALL4J_JAVA_HOME_OVERRIDE=/usr/lib/jvm/java-17-oracle/bin/java
# Uncomment the following line to add additional VM parameters
# INSTALL4J_ADD_VM_PARAMS=
J’ai alors cette erreur:
gzip: sfx_archive.tar.gz: not in gzip format
I am sorry, but the installer file seems to be corrupted.
If you downloaded that file please try it again. If you
transfer that file with ftp please make sure that you are
using binary mode.
Je ne suis pas sûr de savoir quoi faire, pouvez vous m’aider à installer REW sur mon RPi svp?
