Bonjour à tous j’essaye d’installer motion lorsque j’essaye j’ai l’erreur suivante :
pi@smartcleanv1:~ $ motion -c /etc/motion/motion.conf
[0] [NTC] [ALL] conf_load: Processing thread 0 - config file /etc/motion/motion.conf
[0] [NTC] [ALL] motion_startup: Motion 3.2.12+git20140228 Started
[0] [NTC] [ALL] motion_startup: Logging to syslog
[0] [NTC] [ALL] motion_startup: Using log type (ALL) log level (NTC)
[0] [NTC] [ALL] become_daemon: Motion going to daemon mode
[0] [ERR] [ALL] myfopen: Error opening file /var/run/motion/motion.pid with mode w+:
[0] [EMG] [ALL] become_daemon: Exit motion, cannot create process id file (pid file) /var/run/motion/motion.pid:
pi@smartcleanv1:~ $
Broadcast message from systemd-journald@smartcleanv1 (Thu 2017-03-23 16:37:37 CET):
motion[2476]: [0] [EMG] [ALL] become_daemon: Exit motion, cannot create process id file (pid file) /var/run/motion/motion.pid:`
j’ai essayé de faire ça :As a root I created the directory using : Quote: mkdir /var/run/motion then change the permission and it works el7mdllah. Quote: chmod a+rwxt /var/run/motion
mais tjrs rien , des pistes,… :s
