Installation libcamera sur ubuntu 24.04
compilation et installation libcamera, libcamera-app de github, j’ai un pb d’affichage de la fenêtre de prévisualisation.
Au lieu d’envoyer tout cela dans une fenêtre graphique je recois tout ça dans le terminal.
moi@adeept-AWR:~$ libcamera-hello
[0:41:43.444775275] [4140]  INFO Camera camera_manager.cpp:325 libcamera v0.3.2+101-34f4e38a
[0:41:43.531589342] [4143]  WARN RPiSdn sdn.cpp:40 Using legacy SDN tuning - please consider moving SDN inside rpi.denoise
[0:41:43.538059762] [4143]  INFO RPI vc4.cpp:447 Registered camera /base/soc/i2c0mux/i2c@1/ov5647@36 to Unicam device /dev/media4 and ISP device /dev/media1
[0:41:43.538175168] [4143]  INFO RPI pipeline_base.cpp:1120 Using configuration file '/usr/local/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
Preview window unavailable
Mode selection for 1296:972:12:P
    SGBRG10_CSI2P,640x480/0 - Score: 3296
    SGBRG10_CSI2P,1296x972/0 - Score: 1000
    SGBRG10_CSI2P,1920x1080/0 - Score: 1349.67
    SGBRG10_CSI2P,2592x1944/0 - Score: 1567
Stream configuration adjusted
[0:41:43.541284203] [4140]  INFO Camera camera.cpp:1197 configuring streams: (0) 1296x972-YUV420 (1) 1296x972-SGBRG10_CSI2P
[0:41:43.542064212] [4143]  INFO RPI vc4.cpp:622 Sensor: /base/soc/i2c0mux/i2c@1/ov5647@36 - Selected sensor format: 1296x972-SGBRG10_1X10 - Selected unicam format: 1296x972-pGAA
#0 (0.00 fps) exp 33222.00 ag 8.00 dg 1.00
#1 (30.02 fps) exp 33222.00 ag 8.00 dg 1.00
#2 (30.02 fps) exp 33222.00 ag 8.00 dg 1.00
#3 (30.01 fps) exp 33222.00 ag 7.94 dg 1.01
#4 (30.02 fps) exp 33222.00 ag 7.94 dg 1.01
#5 (30.00 fps) exp 33222.00 ag 7.94 dg 1.01
#6 (30.03 fps) exp 33222.00 ag 7.94 dg 1.01
#7 (30.01 fps) exp 33222.00 ag 7.94 dg 1.01
#8 (30.02 fps) exp 33222.00 ag 7.94 dg 1.01
#9 (30.02 fps) exp 33222.00 ag 7.94 dg 1.01
#10 (30.01 fps) exp 33222.00 ag 7.94 dg 1.01
#11 (30.02 fps) exp 33222.00 ag 7.94 dg 1.01
#12 (30.01 fps) exp 33222.00 ag 7.94 dg 1.01
#13 (30.01 fps) exp 33222.00 ag 7.94 dg 1.01
#14 (30.02 fps) exp 33222.00 ag 7.94 dg 1.01
Si tu lance la commande en terminal, il affichera les output texte dans le terminal, normal. Si tu es en SSH, il faut l’orienter vers le DISPLAY principal. ajoute devant ta commande DISPLAY=:0,0 . Exemple;
DISPLAY=:0,0 libcamera-hello
Mais elle n’envoie pas du texte, elle envoie le flux video. dans le terminal au lieu de l’envoyer dans une fenêtre preview.
J’ai de la difficulté à visualiser ton problème.
Selon ton premier message, tu semble ne pas avoir d’image, seulement un log de l’application.
Dans le second, réponse du mien, tu indiques le l’aperçu est dans le terminal et non dans la fenêtre. Ça je ne comprend pas, le terminal n’est que du texte et je ne crois pas que l’application soit en mesure de faire un rendu en ASCII. Alors il sort sur une fenêtre, et ce pendant 5 secondes selon la documentation. Alors tu as une fenêtre qui doit s’ouvrir si tu parle d’aperçu.
Alors est-ce que cette fenêtre est simplement vide ? Noir ? Autre ? Sinon l’application ne sort vraiment que du log dans le terminal ?
Merci de m’éclairer.
Documentations
https://docs.arducam.com/Raspberry-Pi-Camera/Native-camera/Libcamera-User-Guide/#libcamera-hello
https://www.raspberrypi.com/documentation/computers/camera_software.html#rpicam-hello
Je ne vois pas l’image car au lieu d’envoyer le flux de ‹ preview › à une application qui pourrait l’afficher il l’envoi dans le terminal.
ci-dessous une partie du flux
Pour les commandes qui créent une image où une video, celles-ci sont bien créées. Où est passé la fenêtre de preview.
Ca ne m’empêche pas de continuer car libcamera-app c’est pas mon problème, mais je me demandais si libcamera fonctionnait.
