Bonjour.
Je souhaite installer DEZOR sur un raspberry pi 5 (avec version PiOS 64bits installée). On trouve sur le site officiel de DEZOR une version pour linux ARM64. C’est un fichier appimage.
J’ai installé libfuse2 puis j’ai lancé l’installation. Dezor s’ouvre avec des messages d’erreurs.
Checking for update
Update for version 1.3.2 is not available (latest version: 1.3.2, downgrade is disallowed).
checkForUpdatesAndNotify called, downloadPromise is null
[11251:0316/223503.187234:ERROR:gbm_wrapper.cc(293)] Failed to export buffer to dma_buf: No such file or directory (2)
[11251:0316/223503.188227:ERROR:gbm_wrapper.cc(293)] Failed to export buffer to dma_buf: No such file or directory (2)
[11251:0316/223503.188549:ERROR:gbm_wrapper.cc(293)] Failed to export buffer to dma_buf: No such file or directory (2)
[11251:0316/223503.188838:ERROR:gbm_wrapper.cc(293)] Failed to export buffer to dma_buf: No such file or directory (2)
[11251:0316/223503.189040:ERROR:gbm_wrapper.cc(293)] Failed to export buffer to dma_buf: No such file or directory (2)
[11251:0316/223503.189233:ERROR:gbm_wrapper.cc(293)] Failed to export buffer to dma_buf: No such file or directory (2)
[11251:0316/223503.189437:ERROR:gbm_wrapper.cc(293)] Failed to export buffer to dma_buf: No such file or directory (2)
[11251:0316/223503.191187:ERROR:gbm_wrapper.cc(293)] Failed to export buffer to dma_buf: No such file or directory (2)
[11251:0316/223503.191517:ERROR:gbm_wrapper.cc(293)] Failed to export buffer to dma_buf: No such file or directory (2)
[11251:0316/223503.191744:ERROR:gbm_wrapper.cc(293)] Failed to export buffer to dma_buf: No such file or directory (2)
[11251:0316/223503.191952:ERROR:gbm_wrapper.cc(293)] Failed to export buffer to dma_buf: No such file or directory (2)
[11251:0316/223503.192162:ERROR:gbm_wrapper.cc(293)] Failed to export buffer to dma_buf: No such file or directory (2)
[11251:0316/223503.192406:ERROR:gbm_wrapper.cc(293)] Failed to export buffer to dma_buf: No such file or directory (2)
[11251:0316/223503.192599:ERROR:gbm_wrapper.cc(293)] Failed to export buffer to dma_buf: No such file or directory (2)
Error occurred in handler for ‹ sqlite.openDatabase ›: Error: /tmp/.org.chromium.Chromium.hez2iP: cannot open shared object file: No such file or directory
at process.func [as dlopen] (node:electron/js2c/asar_bundle:5:1810)
at Module._extensions…node (node:internal/modules/cjs/loader:1205:18)
at Object.func [as .node] (node:electron/js2c/asar_bundle:5:2037)
at Module.load (node:internal/modules/cjs/loader:988:32)
at Module._load (node:internal/modules/cjs/loader:829:12)
at c._load (node:electron/js2c/asar_bundle:5:13343)
at Module.require (node:internal/modules/cjs/loader:1012:19)
at require (node:internal/modules/cjs/helpers:102:18)
at bindings (/tmp/.mount_Dezor-Q4K5co/resources/app.asar/node_modules/bindings/bindings.js:112:48)
at new Database (/tmp/.mount_Dezor-Q4K5co/resources/app.asar/node_modules/better-sqlite3/lib/database.js:48:64) {
code: ‹ ERR_DLOPEN_FAILED ›
[11251:0316/223506.285532:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
[11251:0316/223509.583851:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
Avez-vous une idée du pourquoi DEZOR plante ?
