Je rencontre un problème sur un PI4 avec une erreur sur le processus dphys-swapfiles sur une configuration vierge (PI4 8G SD 128G)
Setting up dphys-swapfile (20100506-5+rpt2) …
Job for dphys-swapfile.service failed because the control process exited with error code.
See « systemctl status dphys-swapfile.service » and « journalctl -xe » for details.
invoke-rc.d: initscript dphys-swapfile, action « start » failed.
● dphys-swapfile.service - dphys-swapfile - set up, mount/unmount, and delete a swap file
Loaded: loaded (/lib/systemd/system/dphys-swapfile.service; disabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2020-11-22 11:05:57 GMT; 19ms ago
Docs: man:dphys-swapfile(8)
Process: 2631 ExecStart=/sbin/dphys-swapfile setup (code=exited, status=0/SUCCESS)
Process: 2666 ExecStart=/sbin/dphys-swapfile swapon (code=exited, status=255/EXCEPTION)
Main PID: 2666 (code=exited, status=255/EXCEPTION)
Nov 22 11:05:57 raspberrypi systemd[1]: Starting dphys-swapfile - set up, mount/unmount, and delete a swap file…
Nov 22 11:05:57 raspberrypi dphys-swapfile[2631]: computing size, want /var/swap=15480MByte, restricting to config limit: 2048MBytes, checking existing: keeping it
Nov 22 11:05:57 raspberrypi dphys-swapfile[2666]: swapon: /var/swap: swapon failed: Invalid argument
Nov 22 11:05:57 raspberrypi systemd[1]: dphys-swapfile.service: Main process exited, code=exited, status=255/EXCEPTION
Nov 22 11:05:57 raspberrypi systemd[1]: dphys-swapfile.service: Failed with result ‹ exit-code ›.
Nov 22 11:05:57 raspberrypi systemd[1]: Failed to start dphys-swapfile - set up, mount/unmount, and delete a swap file.
dpkg: error processing package dphys-swapfile (–configure):
installed dphys-swapfile package post-installation script subprocess returned error exit status 1
Processing triggers for man-db (2.8.5-2) …
Processing triggers for systemd (241-7~deb10u4) …
Errors were encountered while processing:
dphys-swapfile
E: Sub-process /usr/bin/dpkg returned an error code (1)
Une desinstallation et re-installation ne remédie pas au problème.
Existe-t-il une solution ?
Que va-t-il se passer si la situation ne change pas ?
Merci d’avance,
Phil38
