Bonjour.
Je souhaite télécharger jupyter pour poursuivre la lecture d’un livre sur le machine learning.
Cependant, lorsque je lance cette commande dans la console : « pip3 install jupyter »,
Voici après un peu de temps ce que m’affiche le terminal :
Cleaning up...
Exception:
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2595, in _dep_map
return self.__dep_map
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2457, in __getattr__
raise AttributeError(attr)
AttributeError: _DistInfoDistribution__dep_map
During handling of the above exception, another exception occurred:
File "/usr/lib/python3/dist-packages/pip/basecommand.py", line 122, in main
status = self.run(options, args)
File "/usr/lib/python3/dist-packages/pip/commands/install.py", line 290, in run
requirement_set.prepare_files(finder, force_root_egg_info=self.bundle, bundle=self.bundle)
File "/usr/lib/python3/dist-packages/pip/req.py", line 1266, in prepare_files
req_to_install.extras):
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2401, in requires
dm = self._dep_map
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2597, in _dep_map
self.__dep_map = self._compute_dependencies()
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2621, in _compute_dependencies
parsed = next(parse_requirements(distvers))
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2721, in parse_requirements
"version spec")
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2686, in scan_list
raise ValueError(msg, line, "at", line[p:])
ValueError: ('Expected version spec in', 'widgetsnbextension ~=2.0.0', 'at', ' ~=2.0.0')
Storing debug log for failure in /root/.pip/pip.log
Merci beaucoup de votre attention !
