Auto mount disque windows Cifs error -101
Bonjour à toutes et à tous,
Context :
J’essaye de monter un disque réseaux windows en automatique. sur une rpi4 avec l’OS raspbian oldstable. Ce disque se monte manuellement facilement avec la commande sudo mount -t cifs .... .
Fichier /etc/fstab :
//192.168.1.78/Users/test/Documents/partage /home/jl/Desktop/test cifs auto,_netdev,user,username=user,password=aaaa,vers=3.0,user 0  0
Après un reboot de la RPI le disque ne se monte pas et le résultat avec la commande dmesg est :
[    9.694215] CIFS: Attempting to mount \\192.168.1.78\Users
[    9.694427] CIFS: VFS: Error connecting to socket. Aborting operation.
[    9.694465] CIFS: VFS: cifs_mount failed w/return code = -101
Si j’entre la commande mount -av : le disque réseau ce monte sans problème.
jl@raspberrypi:~ $ sudo mount -av
/proc                    : already mounted
/boot                    : already mounted
/                        : ignored
mount.cifs kernel mount options: ip=192.168.1.78,unc=\\192.168.1.78\Users,vers=3.0,user=user,prefixpath=test/Documents/partage,pass=********
/home/jl/Desktop/test    : successfully mounted
J’ai essayé les même manip sur une machine debian : aucun problème
Annexe :
dmesg complet :
[    4.100621] systemd-journald[144]: File /var/log/journal/40f852ae7a004035b7c45cb57287ed18/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    5.222292] mc: Linux media interface: v0.10
[    5.427972] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    5.470685] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    5.470733] [vc_sm_connected_init]: start
[    5.521945] [vc_sm_connected_init]: installed successfully
[    5.536199] videodev: Linux video capture interface: v2.00
[    5.566062] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    5.591676] bcm2835_audio bcm2835_audio: card created with 8 channels
[    5.649585] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    5.659433] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[    5.665993] rpivid feb10000.codec: Device registered as /dev/video19
[    5.685058] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    5.691501] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[    5.735125] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    5.735193] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    5.744210] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    5.744300] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    5.753813] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    5.754008] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    5.759979] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[    5.760061] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[    5.764288] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[    5.764345] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[    5.784754] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[    5.790060] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[    5.793339] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[    5.797386] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[    5.797444] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    5.797469] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    5.797488] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    5.797507] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    5.843108] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    5.858206] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[    5.859060] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[    5.859694] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[    5.860292] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[    5.860332] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    5.860357] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    5.860375] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    5.860405] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    5.860802] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[    5.969350] brcmstb-i2c fef04500.i2c:  @97500hz registered in polling mode
[    6.094070] brcmstb-i2c fef09500.i2c:  @97500hz registered in polling mode
[    6.612123] Console: switching to colour dummy device 80x25
[    6.643245] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    6.662291] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[    6.713075] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    6.732720] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
[    6.745944] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[    6.766400] Registered IR keymap rc-cec
[    6.766690] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[    6.766939] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input3
[    6.878123] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[    7.074123] Registered IR keymap rc-cec
[    7.074475] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[    7.075026] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input4
[    7.091115] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[    7.091887] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[    7.092683] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[    7.093238] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[    7.093762] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[    7.094246] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[    7.099193] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[    7.128687] brcmfmac: F1 signature read @0x18000000=0x15264345
[    7.140739] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    7.165415] hid-multitouch 0003:1FD2:8102.0003: failed to fetch feature 8
[    7.166164] usbcore: registered new interface driver brcmfmac
[    7.166184] hid-multitouch 0003:1FD2:8102.0003: failed to fetch feature 68
[    7.180319] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
[    7.236143] usb 1-1.4.3: USB disconnect, device number 6
[    7.243025] input: Melfas LGDisplay Incell Touch as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.3/1-1.4.3:1.0/0003:1FD2:8102.0003/input/input5
[    7.249033] Console: switching to colour frame buffer device 240x67
[    7.249101] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[    7.249163] hid-multitouch 0003:1FD2:8102.0003: input,hidraw2: USB HID v1.11 Device [Melfas LGDisplay Incell Touch] on usb-0000:01:00.0-1.4.3/input0
[    7.399197] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[    7.978191] 8021q: 802.1Q VLAN Support v1.8
[    8.082718] uart-pl011 fe201000.serial: no DMA platform data
[    8.178312] Adding 102396k swap on /var/swap.  Priority:-2 extents:10 across:3237292k SSFS
[    8.228963] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[    8.231078] bcmgenet fd580000.ethernet eth0: Link is Down
[    9.688980] Key type cifs.spnego registered
[    9.689023] Key type cifs.idmap registered
[   10.555108] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[   12.318181] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   12.318255] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   13.439191] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
[   13.489859] usb 1-1.4.3: new full-speed USB device number 7 using xhci_hcd
[   13.622644] usb 1-1.4.3: New USB device found, idVendor=1fd2, idProduct=8102, bcdDevice= 1.00
[   13.622664] usb 1-1.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   13.622671] usb 1-1.4.3: Product: LGDisplay Incell Touch
[   13.622676] usb 1-1.4.3: Manufacturer: Melfas
[   13.639777] input: Melfas LGDisplay Incell Touch as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.3/1-1.4.3:1.0/0003:1FD2:8102.0005/input/input6
[   13.640051] hid-multitouch 0003:1FD2:8102.0005: input,hidraw2: USB HID v1.11 Device [Melfas LGDisplay Incell Touch] on usb-0000:01:00.0-1.4.3/input0
[   13.648984] hid-generic 0003:1FD2:8102.0006: hiddev96,hidraw3: USB HID v1.11 Device [Melfas LGDisplay Incell Touch] on usb-0000:01:00.0-1.4.3/input1
[   16.312084] Bluetooth: Core ver 2.22
[   16.312202] NET: Registered PF_BLUETOOTH protocol family
[   16.312207] Bluetooth: HCI device and connection manager initialized
[   16.312227] Bluetooth: HCI socket layer initialized
[   16.312236] Bluetooth: L2CAP socket layer initialized
[   16.312268] Bluetooth: SCO socket layer initialized
[   16.332517] Bluetooth: HCI UART driver ver 2.3
[   16.332544] Bluetooth: HCI UART protocol H4 registered
[   16.335458] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   16.338621] Bluetooth: HCI UART protocol Broadcom registered
[   16.786945] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   16.786966] Bluetooth: BNEP filters: protocol multicast
[   16.786982] Bluetooth: BNEP socket layer initialized
[   16.799584] Bluetooth: MGMT ver 1.22
[   16.824429] NET: Registered PF_ALG protocol family
[   16.999735] Bluetooth: RFCOMM TTY layer initialized
[   16.999785] Bluetooth: RFCOMM socket layer initialized
[   16.999813] Bluetooth: RFCOMM ver 1.11
neofetch :
jl@raspberrypi:~ $ neofetch
  `.::///+:/-.        --///+//-:``    jl@raspberrypi
 `+oooooooooooo:   `+oooooooooooo:    --------------
  /oooo++//ooooo:  ooooo+//+ooooo.    OS: Raspbian GNU/Linux 11 (bullseye) aarch64
  `+ooooooo:-:oo-  +o+::/ooooooo:     Host: Raspberry Pi 4 Model B Rev 1.5
   `:oooooooo+``    `.oooooooo+-      Kernel: 6.1.21-v8+
     `:++ooo/.        :+ooo+/.`       Uptime: 10 mins
        ...`  `.----.` ``..           Packages: 1446 (dpkg)
     .::::-``:::::::::.`-:::-`        Shell: bash 5.1.4
    -:::-`   .:::::::-`  `-:::-       Resolution: 1920x1080
   `::.  `.--.`  `` `.---.``.::`      Terminal: /dev/pts/0
       .::::::::`  -::::::::` `       CPU: BCM2835 (4) @ 1.800GHz
 .::` .:::::::::- `::::::::::``::.    Memory: 260MiB / 1849MiB
Mise a jour :
sur raspberry pi 4 os bookworm, il n’y a aucun problème. Si quelqu’un a une solution pour bullseye je suis preneur.
jl@raspberrypi:~ $ sudo neofetch
       _,met$$$$$gg.          root@raspberrypi
    ,g$$$$$$$$$$$$$$$P.       ----------------
  ,g$$P"     """Y$$.".        OS: Debian GNU/Linux 12 (bookworm) aarch64
 ,$$P'              `$$$.     Host: Raspberry Pi 4 Model B Rev 1.5
',$$P       ,ggs.     `$$b:   Kernel: 6.6.20+rpt-rpi-v8
`d$$'     ,$P"'   .    $$$    Uptime: 2 mins
 $$P      d$'     ,    $$P    Packages: 1539 (dpkg)
 $$:      $$.   -    ,d$$'    Shell: bash 5.2.15
 $$;      Y$b._   _,d$P'      Resolution: 1920x1080
 Y$$.    `.`"Y$$$$P"'         CPU: (4) @ 1.800GHz
 `$$b      "-.__              Memory: 351MiB / 1846MiB
  `Y$$
   `Y$$.
     `$$b.
       `Y$$b.
          `"Y$b._
Dans le log, le montage ce fait AVANT l’établissement réseau (2 secondes plus tard), alors c’est qu’il n’a pas d’accès réseau que le montage ne marche pas. Quand tu l’entre manuellement, le lien est déjà fait.
En complément, théoriquement c’est l’option _netdev qui permet d’attendre l’établissement de la connexion réseau avant de réaliser le montage.
Cette option semble déjà en place dans la ligne du /etc/fstab, essayer de la rempalcer par x-systemd.automount
Source: automount - CIFS mount through fstab not mounting at boot - Ask Ubuntu
Merci pour vos réponses,
J’avais essayé votre solution, mais elle ne marche pas non plus
Pour fstab j’ai fait 2 test avec ou sans netdev:
//192.168.1.78/Users/test/Documents/partage /home/jl/Desktop/test cifs x-systemd.automount,auto,_netdev,user,username=user,password=aaaa,vers=3.0 0  0
//192.168.1.78/Users/test/Documents/partage /home/jl/Desktop/test cifs x-systemd.automount,auto,user,username=user,password=aaaa,vers=3.0 0  0
dmesg :
[   16.723758] CIFS: Attempting to mount \\192.168.1.78\Users
[   16.723863] CIFS: VFS: Error connecting to socket. Aborting operation.
[   16.723881] CIFS: VFS: cifs_mount failed w/return code = -101
[   16.757764] CIFS: Attempting to mount \\192.168.1.78\Users
[   16.758079] CIFS: VFS: Error connecting to socket. Aborting operation.
[   16.758096] CIFS: VFS: cifs_mount failed w/return code = -101
[   16.775414] CIFS: Attempting to mount \\192.168.1.78\Users
[   16.775519] CIFS: VFS: Error connecting to socket. Aborting operation.
[   16.775534] CIFS: VFS: cifs_mount failed w/return code = -101
[   16.791835] CIFS: Attempting to mount \\192.168.1.78\Users
[   16.791932] CIFS: VFS: Error connecting to socket. Aborting operation.
[   16.791947] CIFS: VFS: cifs_mount failed w/return code = -101
[   16.809769] CIFS: Attempting to mount \\192.168.1.78\Users
[   16.809863] CIFS: VFS: Error connecting to socket. Aborting operation.
[   16.809878] CIFS: VFS: cifs_mount failed w/return code = -101
A noté que je suis en ethernet sur ma box et non en wifi
dmesg plus complet :
l@raspberrypi:~ $ sudo dmesg
[    0.026704] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.026741] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.042249] pinctrl core: initialized pinctrl subsystem
[    0.043222] DMI not present or invalid.
[    0.043964] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.047751] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.048057] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.049029] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.049132] audit: initializing netlink subsys (disabled)
[    0.049423] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
[    0.050071] thermal_sys: Registered thermal governor 'step_wise'
[    0.050166] cpuidle: using governor menu
[    0.050609] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.050818] ASID allocator initialised with 32768 entries
[    0.050993] Serial: AMBA PL011 UART driver
[    0.065219] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[    0.085036] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:50:39, variant start
[    0.089048] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
[    0.105223] KASLR enabled
[    0.139750] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[    0.145606] SCSI subsystem initialized
[    0.145886] usbcore: registered new interface driver usbfs
[    0.145947] usbcore: registered new interface driver hub
[    0.146017] usbcore: registered new device driver usb
[    0.146419] usb_phy_generic phy: supply vcc not found, using dummy regulator
[    0.146649] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[    0.147011] pps_core: LinuxPPS API ver. 1 registered
[    0.147025] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.147053] PTP clock support registered
[    0.148205] vgaarb: loaded
[    0.149025] clocksource: Switched to clocksource arch_sys_counter
[    0.149837] VFS: Disk quotas dquot_6.6.0
[    0.149922] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.150109] FS-Cache: Loaded
[    0.150291] CacheFiles: Loaded
[    0.159653] NET: Registered PF_INET protocol family
[    0.160086] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.162880] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.162928] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.162961] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.163210] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.163824] TCP: Hash tables configured (established 16384 bind 16384)
[    0.164058] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.164115] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.164385] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.165262] RPC: Registered named UNIX socket transport module.
[    0.165280] RPC: Registered udp transport module.
[    0.165290] RPC: Registered tcp transport module.
[    0.165301] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.165326] PCI: CLS 0 bytes, default 64
[    0.168111] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.168528] kvm [1]: IPA Size Limit: 44 bits
[    0.169957] kvm [1]: vgic interrupt IRQ9
[    0.170197] kvm [1]: Hyp mode initialized successfully
[    1.316139] Initialise system trusted keyrings
[    1.316678] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    1.324569] zbud: loaded
[    1.327593] NFS: Registering the id_resolver key type
[    1.327648] Key type id_resolver registered
[    1.327659] Key type id_legacy registered
[    1.327786] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.327803] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.329393] Key type asymmetric registered
[    1.329415] Asymmetric key parser 'x509' registered
[    1.329499] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.329794] io scheduler mq-deadline registered
[    1.329811] io scheduler kyber registered
[    1.331765] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 27)
[    1.340619] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[    1.340665] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[    1.340753] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[    1.340839] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x007fffffff -> 0x0400000000
[    1.341883] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[    1.341906] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.341923] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[    1.342010] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[    1.342276] pci 0000:00:00.0: PME# supported from D0 D3hot
[    1.346126] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    1.346411] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
[    1.346611] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
[    1.346735] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
[    1.411119] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[    1.411294] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[    1.411421] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    1.411906] pci 0000:01:00.0: PME# supported from D0 D3hot
[    1.412661] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    1.412710] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[    1.412735] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[    1.412779] pci 0000:00:00.0: PCI bridge to [bus 01]
[    1.412801] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
[    1.414210] simple-framebuffer 3e402000.framebuffer: framebuffer at 0x3e402000, 0x7f8000 bytes
[    1.414232] simple-framebuffer 3e402000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[    1.414830] Console: switching to colour frame buffer device 240x67
[    1.424209] simple-framebuffer 3e402000.framebuffer: fb0: simplefb registered!
[    1.437195] iproc-rng200 fe104000.rng: hwrng registered
[    1.437779] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    1.439391] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[    1.453294] brd: module loaded
[    1.462413] loop: module loaded
[    1.463343] Loading iSCSI transport class v2.0-870.
[    1.468968] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[    1.533179] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[    1.534413] usbcore: registered new interface driver r8152
[    1.534492] usbcore: registered new interface driver lan78xx
[    1.534569] usbcore: registered new interface driver smsc95xx
[    1.583580] pci 0000:00:00.0: enabling device (0000 -> 0002)
[    1.583772] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    1.583805] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[    1.584582] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
[    1.585729] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    1.585753] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[    1.585776] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[    1.586202] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    1.586223] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.586239] usb usb1: Product: xHCI Host Controller
[    1.586253] usb usb1: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
[    1.586267] usb usb1: SerialNumber: 0000:01:00.0
[    1.587081] hub 1-0:1.0: USB hub found
[    1.587164] hub 1-0:1.0: 1 port detected
[    1.588118] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    1.588139] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.588154] usb usb2: Product: xHCI Host Controller
[    1.588167] usb usb2: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
[    1.588179] usb usb2: SerialNumber: 0000:01:00.0
[    1.588882] hub 2-0:1.0: USB hub found
[    1.588976] hub 2-0:1.0: 4 ports detected
[    1.590866] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.591223] dwc_otg: FIQ enabled
[    1.591235] dwc_otg: NAK holdoff enabled
[    1.591245] dwc_otg: FIQ split-transaction FSM enabled
[    1.591261] Module dwc_common_port init
[    1.591848] usbcore: registered new interface driver uas
[    1.591959] usbcore: registered new interface driver usb-storage
[    1.592208] mousedev: PS/2 mouse device common for all mice
[    1.599021] sdhci: Secure Digital Host Controller Interface driver
[    1.599044] sdhci: Copyright(c) Pierre Ossman
[    1.599744] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.603614] ledtrig-cpu: registered to indicate activity on CPUs
[    1.603973] hid: raw HID events driver (C) Jiri Kosina
[    1.604206] usbcore: registered new interface driver usbhid
[    1.604220] usbhid: USB HID core driver
[    1.613857] NET: Registered PF_PACKET protocol family
[    1.613989] Key type dns_resolver registered
[    1.615440] registered taskstats version 1
[    1.615525] Loading compiled-in X.509 certificates
[    1.616486] Key type .fscrypt registered
[    1.616503] Key type fscrypt-provisioning registered
[    1.632746] uart-pl011 fe201000.serial: there is not valid maps for state default
[    1.633567] uart-pl011 fe201000.serial: cts_event_workaround enabled
[    1.633735] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[    1.643093] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    1.643569] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    1.644946] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    1.644967] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[    1.675155] of_cfs_init
[    1.675351] of_cfs_init: OK
[    1.709269] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[    1.709618] Waiting for root device PARTUUID=7a335d59-02...
[    1.760636] mmc1: new high speed SDIO card at address 0001
[    1.811883] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[    1.813088] mmcblk0: mmc0:aaaa SE32G 29.7 GiB
[    1.816381]  mmcblk0: p1 p2
[    1.816971] mmcblk0: mmc0:aaaa SE32G 29.7 GiB (quirks 0x00004000)
[    1.829426] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[    1.829528] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.834617] devtmpfs: mounted
[    1.841160] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[    1.844216] Freeing unused kernel memory: 4160K
[    1.844438] Run /sbin/init as init process
[    1.844449]   with arguments:
[    1.844458]     /sbin/init
[    1.844468]     splash
[    1.844477]   with environment:
[    1.844487]     HOME=/
[    1.844496]     TERM=linux
[    1.995692] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[    1.995735] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.995751] usb 1-1: Product: USB2.0 Hub
[    1.997621] hub 1-1:1.0: USB hub found
[    1.997925] hub 1-1:1.0: 4 ports detected
[    2.151841] systemd[1]: System time before build time, advancing clock.
[    2.297107] usb 1-1.1: new low-speed USB device number 3 using xhci_hcd
[    2.346162] NET: Registered PF_INET6 protocol family
[    2.348268] Segment Routing with IPv6
[    2.348310] In-situ OAM (IOAM) with IPv6
[    2.405857] usb 1-1.1: New USB device found, idVendor=413c, idProduct=301a, bcdDevice= 1.00
[    2.405899] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.405915] usb 1-1.1: Product: Dell MS116 USB Optical Mouse
[    2.405929] usb 1-1.1: Manufacturer: PixArt
[    2.415168] input: PixArt Dell MS116 USB Optical Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:413C:301A.0001/input/input0
[    2.415712] hid-generic 0003:413C:301A.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Dell MS116 USB Optical Mouse] on usb-0000:01:00.0-1.1/input0
[    2.418143] systemd[1]: systemd 247.3-7+rpi1+deb11u2 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[    2.419237] systemd[1]: Detected architecture arm64.
[    2.420957] systemd[1]: Set hostname to <raspberrypi>.
[    2.498023] usb 1-1.3: new low-speed USB device number 4 using xhci_hcd
[    2.633409] usb 1-1.3: New USB device found, idVendor=413c, idProduct=2105, bcdDevice= 3.52
[    2.633455] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.633474] usb 1-1.3: Product: Dell USB Keyboard
[    2.633488] usb 1-1.3: Manufacturer: Dell
[    2.666732] input: Dell Dell USB Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:413C:2105.0002/input/input1
[    2.725858] hid-generic 0003:413C:2105.0002: input,hidraw1: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-0000:01:00.0-1.3/input0
[    2.805066] usb 1-1.4: new high-speed USB device number 5 using xhci_hcd
[    2.916111] usb 1-1.4: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=57.20
[    2.916152] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.916169] usb 1-1.4: Product: USB2.1 Hub
[    2.916183] usb 1-1.4: Manufacturer: GenesysLogic
[    2.918164] hub 1-1.4:1.0: USB hub found
[    2.918548] hub 1-1.4:1.0: 3 ports detected
[    3.188980] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[    3.241077] usb 1-1.4.3: new full-speed USB device number 6 using xhci_hcd
[    3.382365] usb 1-1.4.3: New USB device found, idVendor=1fd2, idProduct=8102, bcdDevice= 1.00
[    3.382402] usb 1-1.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.382419] usb 1-1.4.3: Product: LGDisplay Incell Touch
[    3.382432] usb 1-1.4.3: Manufacturer: Melfas
[    3.393049] systemd[1]: Queued start job for default target Graphical Interface.
[    3.405156] input: Melfas LGDisplay Incell Touch as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.3/1-1.4.3:1.0/0003:1FD2:8102.0003/input/input2
[    3.405785] hid-generic 0003:1FD2:8102.0003: input,hidraw2: USB HID v1.11 Device [Melfas LGDisplay Incell Touch] on usb-0000:01:00.0-1.4.3/input0
[    3.412483] hid-generic 0003:1FD2:8102.0004: hiddev96,hidraw3: USB HID v1.11 Device [Melfas LGDisplay Incell Touch] on usb-0000:01:00.0-1.4.3/input1
[    3.418133] systemd[1]: Created slice system-getty.slice.
[    3.419952] systemd[1]: Created slice system-modprobe.slice.
[    3.421151] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    3.422159] systemd[1]: Created slice User and Session Slice.
[    3.422804] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.424173] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.425061] systemd[1]: Reached target Slices.
[    3.425332] systemd[1]: Reached target Swap.
[    3.428945] systemd[1]: Listening on Syslog Socket.
[    3.429934] systemd[1]: Listening on fsck to fsckd communication Socket.
[    3.430417] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    3.431888] systemd[1]: Listening on Journal Audit Socket.
[    3.432789] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.434036] systemd[1]: Listening on Journal Socket.
[    3.438111] systemd[1]: Listening on udev Control Socket.
[    3.439099] systemd[1]: Listening on udev Kernel Socket.
[    3.440274] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    3.457702] systemd[1]: Mounting POSIX Message Queue File System...
[    3.463065] systemd[1]: Mounting RPC Pipe File System...
[    3.469486] systemd[1]: Mounting Kernel Debug File System...
[    3.475641] systemd[1]: Mounting Kernel Trace File System...
[    3.476231] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[    3.483755] systemd[1]: Starting Restore / save the current clock...
[    3.490646] systemd[1]: Starting Set the console keyboard layout...
[    3.497164] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    3.503853] systemd[1]: Starting Load Kernel Module configfs...
[    3.510701] systemd[1]: Starting Load Kernel Module drm...
[    3.517999] systemd[1]: Starting Load Kernel Module fuse...
[    3.529849] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    3.535273] systemd[1]: Starting File System Check on Root Device...
[    3.546092] systemd[1]: Starting Journal Service...
[    3.579363] systemd[1]: Starting Load Kernel Modules...
[    3.598877] systemd[1]: Starting Coldplug All udev Devices...
[    3.621697] systemd[1]: Mounted POSIX Message Queue File System.
[    3.622786] systemd[1]: Mounted RPC Pipe File System.
[    3.623792] systemd[1]: Mounted Kernel Debug File System.
[    3.624813] systemd[1]: Mounted Kernel Trace File System.
[    3.630016] fuse: init (API version 7.37)
[    3.635588] systemd[1]: Finished Restore / save the current clock.
[    3.639068] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    3.641783] systemd[1]: modprobe@configfs.service: Succeeded.
[    3.643511] systemd[1]: Finished Load Kernel Module configfs.
[    3.646905] systemd[1]: modprobe@fuse.service: Succeeded.
[    3.648642] systemd[1]: Finished Load Kernel Module fuse.
[    3.674238] i2c_dev: i2c /dev entries driver
[    3.678059] systemd[1]: Mounting FUSE Control File System...
[    3.684645] systemd[1]: Mounting Kernel Configuration File System...
[    3.691184] systemd[1]: Started File System Check Daemon to report status.
[    3.700901] systemd[1]: Finished Load Kernel Modules.
[    3.702460] systemd[1]: Mounted FUSE Control File System.
[    3.708408] systemd[1]: Starting Apply Kernel Variables...
[    3.753210] systemd[1]: Mounted Kernel Configuration File System.
[    3.766412] systemd[1]: Finished Apply Kernel Variables.
[    3.787507] systemd[1]: Finished File System Check on Root Device.
[    3.810785] systemd[1]: Starting Remount Root and Kernel File Systems...
[    3.813681] systemd[1]: modprobe@drm.service: Succeeded.
[    3.815346] systemd[1]: Finished Load Kernel Module drm.
[    3.964105] systemd[1]: Started Journal Service.
[    3.977082] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[    4.077941] systemd-journald[142]: Received client request to flush runtime journal.
[    4.086997] systemd-journald[142]: File /var/log/journal/40f852ae7a004035b7c45cb57287ed18/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    5.292124] mc: Linux media interface: v0.10
[    5.427623] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    5.518125] bcm2835_audio bcm2835_audio: card created with 8 channels
[    5.562257] videodev: Linux video capture interface: v2.00
[    5.627788] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    5.630147] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    5.630186] [vc_sm_connected_init]: start
[    5.634672] [vc_sm_connected_init]: installed successfully
[    5.772835] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    5.800748] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    5.820357] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    5.833224] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    5.833320] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    5.857720] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[    5.883478] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[    5.894261] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    5.894772] rpivid feb10000.codec: Device registered as /dev/video19
[    5.908113] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    5.908188] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    5.919464] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    5.919540] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    5.920568] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[    5.923962] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[    5.935294] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[    5.938624] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[    5.938797] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[    5.946371] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[    5.946426] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    5.946451] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    5.946476] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    5.946511] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    5.958687] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[    5.958769] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[    5.981877] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[    5.983319] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[    5.997491] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[    6.024964] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[    6.025073] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    6.025105] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    6.025147] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    6.025167] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    6.044577] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[    6.227741] brcmstb-i2c fef04500.i2c:  @97500hz registered in polling mode
[    6.235931] brcmstb-i2c fef09500.i2c:  @97500hz registered in polling mode
[    6.476381] input: Melfas LGDisplay Incell Touch as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.3/1-1.4.3:1.0/0003:1FD2:8102.0003/input/input3
[    6.741060] hid-multitouch 0003:1FD2:8102.0003: input,hidraw2: USB HID v1.11 Device [Melfas LGDisplay Incell Touch] on usb-0000:01:00.0-1.4.3/input0
[    6.792116] Console: switching to colour dummy device 80x25
[    6.818743] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    6.841570] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[    6.878389] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    6.894863] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[    6.925566] Registered IR keymap rc-cec
[    6.935425] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[    6.937568] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input4
[    7.030177] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[    7.052455] Registered IR keymap rc-cec
[    7.052681] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[    7.052909] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input5
[    7.060983] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[    7.061681] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[    7.062176] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[    7.063191] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[    7.063700] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[    7.064013] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[    7.064414] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[    7.070319] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
[    7.090735] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
[    7.113585] brcmfmac: F1 signature read @0x18000000=0x15264345
[    7.124721] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    7.130338] usbcore: registered new interface driver brcmfmac
[    7.219933] Console: switching to colour frame buffer device 240x67
[    7.220047] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[    7.231463] usb 1-1.4.3: USB disconnect, device number 6
[    7.385978] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[    7.772394] 8021q: 802.1Q VLAN Support v1.8
[    7.781972] uart-pl011 fe201000.serial: no DMA platform data
[    8.035409] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[    8.038532] bcmgenet fd580000.ethernet eth0: Link is Down
[    8.153184] Adding 102396k swap on /var/swap.  Priority:-2 extents:10 across:3237292k SSFS
[    9.668839] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[   11.941042] usb 1-1.4.3: new full-speed USB device number 7 using xhci_hcd
[   12.073802] usb 1-1.4.3: New USB device found, idVendor=1fd2, idProduct=8102, bcdDevice= 1.00
[   12.073823] usb 1-1.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   12.073829] usb 1-1.4.3: Product: LGDisplay Incell Touch
[   12.073834] usb 1-1.4.3: Manufacturer: Melfas
[   12.095277] input: Melfas LGDisplay Incell Touch as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.3/1-1.4.3:1.0/0003:1FD2:8102.0005/input/input6
[   12.096003] hid-multitouch 0003:1FD2:8102.0005: input,hidraw2: USB HID v1.11 Device [Melfas LGDisplay Incell Touch] on usb-0000:01:00.0-1.4.3/input0
[   12.104085] hid-generic 0003:1FD2:8102.0006: hiddev96,hidraw3: USB HID v1.11 Device [Melfas LGDisplay Incell Touch] on usb-0000:01:00.0-1.4.3/input1
[   12.129213] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   12.129266] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   14.018761] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
[   15.586365] Bluetooth: Core ver 2.22
[   15.586456] NET: Registered PF_BLUETOOTH protocol family
[   15.586462] Bluetooth: HCI device and connection manager initialized
[   15.586479] Bluetooth: HCI socket layer initialized
[   15.586487] Bluetooth: L2CAP socket layer initialized
[   15.586501] Bluetooth: SCO socket layer initialized
[   15.604731] Bluetooth: HCI UART driver ver 2.3
[   15.604755] Bluetooth: HCI UART protocol H4 registered
[   15.605326] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   15.606169] Bluetooth: HCI UART protocol Broadcom registered
[   15.882939] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   15.882961] Bluetooth: BNEP filters: protocol multicast
[   15.882977] Bluetooth: BNEP socket layer initialized
[   15.888363] Bluetooth: MGMT ver 1.22
[   15.900771] NET: Registered PF_ALG protocol family
[   16.015367] Bluetooth: RFCOMM TTY layer initialized
[   16.015409] Bluetooth: RFCOMM socket layer initialized
[   16.015430] Bluetooth: RFCOMM ver 1.11
[   16.720805] Key type cifs.spnego registered
[   16.720832] Key type cifs.idmap registered
Il me semble que l’option _netdev ne soit pas cumulable avec x-systemd.automount
Essayer de modifier autoen no //192.168.1.78/Users/test/Documents/partage /home/jl/Desktop/test cifs x-systemd.automount,auto,user,username=user,password=aaaa,vers=3.0 0 0`
Essayer également l’option x-systemd.device-timeout=60s
```//192.168.1.78/Users/test/Documents/partage /home/jl/Desktop/test cifs x-systemd.automount,x-systemd.device-timeout=60s,noauto,user,username=user,password=aaaa,vers=3.0 0 0`
Autre solution est de prendre la commande manuel et de l’ajouter dans un boot (profile ou cron) pour le faire automatiquement. Cron et Profile sont habituellement après l’initialisation du réseau.
J’ai essayé le 60s et pas de résultat probant. le problème le démarrage se fait toujours dans le même ordre (pas de décalage du mount)
Merci pour ton aide A +
dmesg :
[    9.147254] CIFS: VFS: Error connecting to socket. Aborting operation.
[    9.147289] CIFS: VFS: cifs_mount failed w/return code = -101
[   12.189823] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   12.189864] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   12.217684] usb 1-1.4.3: new full-speed USB device number 7 using xhci_hcd
[   12.354533] usb 1-1.4.3: New USB device found, idVendor=1fd2, idProduct=8102, bcdDevice= 1.00
[   12.354551] usb 1-1.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   12.354557] usb 1-1.4.3: Product: LGDisplay Incell Touch
[   12.354562] usb 1-1.4.3: Manufacturer: Melfas
[   12.372013] input: Melfas LGDisplay Incell Touch as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.3/1-1.4.3:1.0/0003:1FD2:8102.0005/input/input6
[   12.372693] hid-multitouch 0003:1FD2:8102.0005: input,hidraw2: USB HID v1.11 Device [Melfas LGDisplay Incell Touch] on usb-0000:01:00.0-1.4.3/input0
[   12.381027] hid-generic 0003:1FD2:8102.0006: hiddev96,hidraw3: USB HID v1.11 Device [Melfas LGDisplay Incell Touch] on usb-0000:01:00.0-1.4.3/input1
[   13.919055] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
[   14.306928] CIFS: Attempting to mount \\192.168.1.78\Users
[   14.307031] CIFS: VFS: Error connecting to socket. Aborting operation.
[   14.307047] CIFS: VFS: cifs_mount failed w/return code = -101
[   15.385121] Bluetooth: Core ver 2.22
[   15.385226] NET: Registered PF_BLUETOOTH protocol family
[   15.385232] Bluetooth: HCI device and connection manager initialized
[   15.385249] Bluetooth: HCI socket layer initialized
[   15.385256] Bluetooth: L2CAP socket layer initialized
[   15.385269] Bluetooth: SCO socket layer initialized
[   15.396792] Bluetooth: HCI UART driver ver 2.3
[   15.396814] Bluetooth: HCI UART protocol H4 registered
[   15.396881] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   15.397057] Bluetooth: HCI UART protocol Broadcom registered
[   15.623855] CIFS: Attempting to mount \\192.168.1.78\Users
[   15.624006] CIFS: VFS: Error connecting to socket. Aborting operation.
[   15.624028] CIFS: VFS: cifs_mount failed w/return code = -101
J’ai fait un service avec systemctl qui se lance toute les 30 secondes, ca marche
une ligne dans profile ne fonctionne pas car elle ne se lance pas a l’ouverture d’une session qui se log en automatique
[Unit]
Description=Monte tous les systèmes de fichiers de /etc/fstab
[Service]
Type=simple
ExecStart=/bin/mount -a
Restart=always
RestartSec=30
[Install]
WantedBy=multi-user.target
