c’est un L minicusle
-l aprés fdisk
sudo fdisk -l
-l aprés fdisk
sudo fdisk -l
a oui, ca va effectivement beaucoup mieux lol :slight_smile.
voici le resultat :
login as: pi
pi@192.168.1.98’s password:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Feb 3 19:33:22 2017 from fragator-pc
pi@raspberrypi:~ $ sudo fdisk -l
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram4: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram5: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram6: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram7: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram8: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram9: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram10: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram11: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram12: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram13: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram14: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram15: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk0: 29.8 GiB, 32010928128 bytes, 62521344 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x6689726d
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 8192 137215 129024 63M c W95 FAT32 (LBA)
/dev/mmcblk0p2 137216 62521343 62384128 29.8G 83 Linux
Disk /dev/sda: 7.5 GiB, 8022654976 bytes, 15669248 sectors
Disklabel type: dos
Disk identifier: 0x00000000
/dev/sda1 63 15669247 15669185 7.5G b W95 FAT32
pi@raspberrypi:~ $
nikel on a trouver ta clée usb elle est la
tape sa maintenant ,pour monter temporairement ta clée usb
sudo mount /dev/sda /media/
ensuite retape
find /media/
et met moi le résultat
attention si tu éteins ton pi le point de montage va sauter et tu devra retaper
Ok, je m occupe de ca demain.
Encore merci
j ai eu un petit moment pour le faire, voici le resultat :
login as: pi
Last login: Sat Feb 4 00:43:45 2017 from fragator-pc
pi@raspberrypi:~ $ sudo mount /dev/sda /media/
mount: wrong fs type, bad option, bad superblock on /dev/sda,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so.
pi@raspberrypi:~ $ find /media/
/media/
pi@raspberrypi:~ $
Aie j’aime pas ce message d’erreur
on va essayer en spécifiant le type
on modifie légèrement la commande
sudo mount -t vfat /dev/sda /media/
dis moi si tu un message d’erreur, si le terminal n’affiche rien ,c’est que c’est bon
et tu pourra ré-enchaîné par un
find /media/
remet moi les résultat
apparement, j ai encore un message d erreur :
login as: pi
Last login: Sat Feb 4 19:11:53 2017 from fragator-pc
pi@raspberrypi:~ $ sudo mount -t vfat /dev/sda /media/
dmesg | tail or so.
pi@raspberrypi:~ $
petite question : dans ta commande « sudo mount -t vfat /dev/sda /media/ », il y a bien un espace entre vfat, et le /, ainsi que entre sda, et le /???
oui , alors la je vois pas d’où viens le problème mais on va tenter avec tenter avec le deuxième point de ta clée
sudo mount -t vfat /dev/sda1 /media/
dis moi se que tu a
pas de message d erreur, le terminal n afiche rien :
login as: pi
Last login: Sat Feb 4 19:13:45 2017 from fragator-pc
pi@raspberrypi:~ $ sudo mount -t vfat /dev/sda1 /media/
pi@raspberrypi:~ $
j ai donc enchainé avec : find /media/ :
login as: pi
/media/
/media/pour coffre.mp4
pi@raspberrypi:~ $
ca a donc fonctionner ![]()
Ok pas compris pourquoi tu avais deux partition,sda et sda1 enfin bref
maintenant on va pourvoir copié coller la vidéo ,donc si tu à étaint ton pi entre temps on doit remonter
la clés car c’est un montage temporaire (on pourais faire que se soit éterenel )
si tu a pas étaint ton oublie cette étapes
on va copiée le fichier cette fois si dans le dossier Videos (non il n’y a pas de faute d’orthographe )
cp « /media/pour coffre.mp4 » /home/pi/Videos
les « » sont très important car sa permet d’ignorer l’espace, car tu a un espace entre pour et coffre .
Parenthèse :
En bash (le langage du terminal ) un espace marque la fin d’une instruction ou plutôt une liaison pour la prochaine , on aurais pus écrire sa aussi en utilisant un séparateur syntaxe qui permet d’échapper l’espace
cp /media/pour\ coffre.mp4 /home/pi/Videos
t’inquiète pas tapes pas sa , c’est juste pour la culture et c’est pourquoi on vois des truc du genre pour_coffre.mp4
pour éviter de se faire chié avec l’espace
Fin de la parenthèse
Dis mois dés que tu a copier le fichier
il se peut vu ta clés nous a fait chier qu’il y ai un soucis de permission si c’est le cas tu aura un message d’erreur ,donc si c’est le cas met le moi et on corrigera
slt,
merci pour les parenthese, je comprend mieux maintenant du coup, les espacement.
apres avoir copier le fichier, j ai ce resultat :
login as: pi
/media/
pi@raspberrypi:~ $ cp « /media/pour coffre.mp4 » /home/pi/Videos
pi@raspberrypi:~ $
le terminal n afiche rien en faite.
ok fais un petit un
ls /home/pi/Videos
login as: pi
Last login: Sun Feb 5 08:30:35 2017 from fragator-pc
pi@raspberrypi:~ $ ls /home/pi/Videos
/home/pi/Videos
pi@raspberrypi:~ $
Ah la vidéo apparaît pas bizarre sa,alors qu’il la bien copier essaye avec un
find /home/pi/Videos
Ok, j essai ce soir, je suis parti au boulot…
Merci encore
voici le resultat :
login as: pi
Last login: Sun Feb 5 13:39:49 2017 from fragator-pc
pi@raspberrypi:~ $ find /home/pi/Videos
/home/pi/Videos
pi@raspberrypi:~ $
comme apparement ca n a pas l air de fonctionner du tonnerre, j ai par precaution, changer de clef usb, et tout recommencer a la base.
j arrive a un resultat apparement plus concluant :
login as: pi
Last login: Sun Feb 5 19:40:07 2017
pi@raspberrypi:~ $ find /media/pi
find: `/media/pi’: No such file or directory
pi@raspberrypi:~ $ ls /media
Disklabel type: dos
Disk /dev/sda: 14.7 GiB, 15744892928 bytes, 30751744 sectors
Disklabel type: dos
Disk identifier: 0x6b8163c0
/dev/sda1 2048 30734335 30732288 14.7G c W95 FAT32 (LBA)
pi@raspberrypi:~ $ sudo mount /dev/sda1 /media/
^[[3~/media/
pi@raspberrypi:~ $
plus que la copie maintenant
le terminal n affiche rien.
login as: pi
Last login: Sun Feb 5 19:40:19 2017 from fragator-pc
pi@raspberrypi:~ $
du coup, j ai fait un : ls /home/pi/Videos :
login as: pi
/home/pi/Videos
pi@raspberrypi:~ $
